Sponsored by: CARiD
2006 Tundra Driveshaft Replacement
Old Sep 11, 2021 | 07:59 AM
Desmond98's Avatar
Per Toyota I am having to replace my rear driveshaft assembly. They want $1900 for the part alone. Seeing some other options for way less (rebuilt/used, aftermarket, custom built). I am looking at six states distributors ATM, but have no idea if I am setting myself up for a disappointment. Can anyone tell me if there is a better solution, a potential upgrade that I don't know about, or am I on the right track?
Thanks!
Old Sep 11, 2021 | 11:39 AM
2ToyGuy's Avatar
Is the drive shaft bent or damaged somehow so it no longer rotates true, or is out of balance, or is it just the u-joints?
A lot of drive shaft speciality shops will balance a drive shaft, if that's the problem, for a reasonable price. They will also replace bad u-joints quickly and cheaply.
Many shops will also manufacture a new driveshaft, including balancing it and putting in u-joints for a better price than the $1900.00 you got quoted. Shop around a little, make some calls to local shops, check the local junk yards, and so on. I'd wager you can get a replacement drive shaft for a decent price.
Let us know how things go for ya!
Pat☺
weisbeck20
Oct 9, 2014 01:18 PM
traxxi2003
Apr 3, 2010 07:19 AM
BT17R
59
Nov 22, 2006 07:44 AM
914runner
May 30, 2006 01:17 AM
ToyotaTRD
Oct 3, 2005 04:43 PM
