99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 18, 2016, 01:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra 4WD - Four Wheel Drive Guides
Print Wikipost
03 Tundra Driveshaft Problem
Old Oct 9, 2014 | 12:55 PM
weisbeck20's Avatar
Hello. I am new to this site, looking for help and friendly discussion regarding my 2003 Tundra 3.4 4x4 with automatic transmission.
My Ujoint recently went out as I was driving. As yoou may know, the rear driveshaft in this truck is a 2 piece shaft with a knuckle in the middle, and a support -O- bearing in the middle. Unfortunately, the U joint damaged my driveshaft to the point where my local mechanic has said it is no longer useable. He has found a used driveshaft for me, but it is going to cost about $1200 to put it in with new U joints. I do not like the price, nor the complexity of this style of driveshaft. My question is, does anyone know is the driveshaft from a 2003 tundra with the same meotor and trans, but in a 2 wheel drive version (single shaft driveshaft) will fit in my truck? This would save me about $900 as they are only $200 new with U joints already installed. I do no offroading, so ground clearance isnt an issue there. Thanks for the input!
Old Oct 9, 2014 | 01:18 PM
driveshafter's Avatar
no because of the tcase pm me with a mesurement from flange to flange or flange to end of output shaft and ill tell you if you can make a 1 piece
taller1
Nov 13, 2018 02:34 PM
Ironmike4x4
Feb 3, 2016 11:13 AM
crazypaint
Aug 13, 2015 04:32 PM
mengquis
Jul 13, 2015 10:39 AM
Suprarossa
Jul 6, 2015 05:21 AM
