View Full Version : Newbie Tech Section
- 22R help!
- Factory U bolts
- 7mge coil, and emissions junk
- 1987 Toyota SR5 EFI with blown HG?
- What is this? Brake booster connection
- help with death wobble
- Newbie? What would you do? If your 89 engine went bad?
- Compression check done...
- 70k same trans noise! cant find same description
- Will 3.0 throttle body work on 22re
- bang for the buck - engine mods
- snorkel question
- replacement seat help
- 03 Tacoma TRD, Struts or shocks?
- 91' 22RE 4x4 pickup speedometer not working!
- 94 distributor question
- Does anyone know what seats will bolt right in
- 1986 toyota 4runner/ window problems
- maxxis bighorns
- 22r engine help
- 1992 4x4 22re timing chain blues
- Talked with mechanic about new u-joints & he said mine might be "staked"...
- 86 22re minus turbo running wierd lol
- Frame rust solutions?
- 22ret head height
- help with c.o.r
- Is this noise coming from the u-joint or center/carrier bearing (VIDEO)
- ADD to manual hubs
- Alternator Problems
- Help with brakes
- Charge light only, no blinkers
- E-locker help
- New front pads grind only for 1st mile??
- 96 4 runner head job
- ss tsls 10.50/12.50
- Direct me in the right... direction?
- Swaybar bushings
- IFS Lift
- valve cover gasket write up?
- Replacing ADD drive flanges with Manuals hubs
- i need some education on lockers, instail, function ,price
- Clicking noise under truck - '84 22r
- New to the toyota scene.
- Injectors not opening
- 3.0 clicking noise
- Toyota Diesels
- Bilstein Shocks
- How do I tell what tranny I have?
- ready lift 2.75 on 2011 tacoma info
- Spool for front diff
- Open Differential or Not
- Are all 22REs compatible?
- 4wheel questons
- 94 t-100 tach wire
- 89 4runner more leg room
- '94 PU Performance Upgrades
- is 3rd member from automatic same as standard one?
- clutch pedal adjustment 86 4runner
- Which TOYOTA supplied grease to use in spindles?
- TPS Screw size
- maybe it won't be stock
- terminals of ECM pulse generation
- 86 pickup idles good but dies out as soon as you put it under a load
- sticking door locks
- Want to rebuild 22re any advice on parts ect
- TPS issue on 22RE
- Idler Arm Zerk, Where to put it?
- Question about Bilstein HD shocks
- 1990 toyota 3.0 4runner water pump replacement
- optioned out `86 4x4
- Frame swap: 93-->88
- 2010 Taco leafs on an 88?
- 1988 yota problem with new motor
- Looking for new wheels, anything i should be aware of?
- what bead???????
- Tires! Tires! Tires!
- Diff Bearing question
- VSC/Trac lights/front end shakes when accel.
- 22r to 22re
- Just bought a Toyota pickup
- Transmission help!
- 4wd question 2002 4runner what am I in?
- Gas gauge problem
- New leaf springs or Zuk lift 1989 4runner
- rearview mirror upgrade
- 86 p/u 4wd OEM head lights
- engine runs on
- Upgrade Advice 1985 Yota
- 3rd row seating for my 89 runner
- Tire Recommendations! I'm lost
- 1994 brake light help
- Got an axle, now???
- selectro hubs
- Fuel pump
- New owner looking for direction
- front axle for rear steer?
- New 4runner owner just some question
- To swap or not to swap?
- Lean Air Mixture Fault
- 2003 Tacoma Hood latch/grille mod
- Rebuild 3.0/Swap 3.4
- clicking under acceleration
- Bilstein 5100 and the Bilstein B6 HD....?
- '90 pickup engine problems
- Rear Wiper replacement? 2002 4RUNNER
- 1989 4runner v6 installing 5.29 gears help
- temp runs normal then spikes to hot
- My truck rattles while underload and revving around 2900 rpm and up
- wheel spacers on hub solid axle
- Headers 22re
- 2gen brake rotor problem
- 4-5 rough country lift what kind of leaf springs would level it out
- 22r Carb Problems!
- 85 4runner lift and crossover kits? just buy and instail.
- cheap tricks for newbies
- Remote Oil Filter Installed On Gen 3 4Runner
- 2002 4x4 Sport - Stock Suspension Upgrade??
- 1994 Toyotoa Pickup 4x4 22re gear question
- 1995 3vze having trouble starting
- rear leaf spring trouble
- Need Help with HOW TO DISABLE DRL on my 2001 Yota 4runner
- my sticks touch
- Seeking advise on engine w/200k: repair or replace?
- Whats the best way to upgdrade my DD to make it more offroad capable
- Sway and torsion bar swap help...
- Timing an 87 P/U 22R w/ vacum advance
- IFS Suspension Rebuild
- 94 toyota
- Need Help with body mounts. 84vs92 cab
- 1" bore MC upgrade question 85 4Runner
- still overheating
- 82 pickup
- Lets talk gear oil...
- 89 3.0 surging, smoking and sputtering
- V06 headgasket campaign advice?
- stubborn
- 2002 Tacoma 4wd stuttering when braking
- seat swap qs
- 3 core auminum vs 4 core copper radiators?
- What are the lowest gears TRD e-locker will accommodate?
- 91 pickup no rear bumper with trailor hitch looks ?
- ARB Compatible 3rds
- Rear Differential Drain & Fill Plugs
- 22r Cold Hard Start
- v-8 swap
- 99 4runner oil light on
- Idle problems
- What is the pros and cons with using leaf springs instead of coils
- stumbles when under load
- interchangeable parts
- Tick Tick Tick
- 90 v6 problem passing emissions
- Post mudding maintenance
- how bad are the 2nd gen 4Runner (3.0,auto)
- Lspv
- 93 pickup needs lift in rear, no blocks please
- exhaust ????
- taking off emission system on 82 toyota
- Carburated or Fuel injected?
- LSV-BP problems
- Advice Replacing Parts
- 3.4 what years are interchangble ?
- timing chain and BHG
- 22rte 4runner runs no power help??
- Torsion bar bolt sizes
- can someone enlighten me? IFS outers on an SA
- t-100 diff will not fit an 87 4runner
- '87 Toyota auto to manual swap
- Best front axle assembly?
- elockers
- 89-94 Tail Lights on 86??
- Starter or Alternator? Not starting
- open diff in front, passenger tire in air spinning, driver stationary.
- School me on sliders
- Having 4x4 trouble
- Need Expert Modification Advice, Toyota Pickup newb here (slight problem)
- need help identifying engine...
- regear question
- IFS Does not Flex
- turbo 2.7l
- Newb question about leaf springs
- Got my first Toyota (1983 4x4) and need some advise
- is a 2.7 l from a 2000 different then a 1995?
- 96 T100 Electrical Challenge
- TRD Beadlocks are fake
- 3rd cylinder kaput
- Pre run help
- '95 3.0 Runner, head gasket, rebuild or part out?
- 1990 4Runner rear window replacement
- 22r and 3.0 gearbox compatability
- Hit something on the highway and lost all my coolant
- Hg or head crack
- 82 4x4 truck alternator wont charge battery
- Port and polish for increased fuel economy?
- Hesitation/Shudder/Loss of Power.... Please help me pin point my problem
- Knock Knock, where is it coming from?
- Total Caos Idler ARM vs. Idler arm Brace/TRUSS
- What Is My 89 Pickup V6 Rear Axle Interchangable With?
- 85 4Runner wheel cylinder removal problem
- front suspension lift question (pick up)
- Tire and rim options
- does anyone have a g52 tranny that i can buy?
- 87 Toyota pickup radiator question
- Tranny Interchange?
- Transfer/Tranny ?
- Engine Builders in Portland Oregon-???
- 1997 Tacoma Diesel ???
- Pro Comp EXPK5055B 4" suspension lift kit feedback for new guy
- Mpg 22re - 3.4l
- 22re wiring harness
- Built 22RE:How much power can I expect?
- axle swap
- Longer rear shocks with stock coils?
- Will ball joint spacers break?
- Sharpie pen on interior
- motor frame mount problem!
- Sky Off Road Ring and Pinion's?
- 22r rebuilt oilburner
- stopping rust
- 89 4runner need help
- 3vze Seafoam
- Does an automatic locker lock in reverse?
- 82 4x4 lift and steering problem
- The name this 22r/22re O-Ring/Gasket game
- rear backing plates/complete axle assembly question
- my starter problem....:(
- Loss of power/stalling
- welding sliders to frame, input?
- Sheared Keyway HELP!!!!!!
- 02 3.4V6 Oil Leaks
- 22r block 22re head, accessory help
- early and late 22r blocks...
- trans cooler lines
- anyone know of a neoprene oil pan gasket for 22r?
- Starts and kills immediately
- RR DIFF LOCK? ... Really?
- New guy with 3.0 issues...
- Moderator Contact Info
- Decisions, Decisions - Rebuilding my 93 4WD pickup
- Digital gauges
- finding window channel for window with wing window
- how hard would it be to put a 95 v6 in a 81 pickup
- Having trouble getting 22rte running right
- HELP: running but hardly has any power
- How to install gears myself
- 1st gen 4runner seat questions
- Info needed with changing timing chain and gears
- Read Driveline with a new 5 speed in 81 Pickup
- 1991 SR5 Pickup transmission problems
