View Full Version : Newbie Tech Section
- 87 22R hi idle not kicking down until...
- Need help with my 91 Runner PLEASE
- 92 4runner v6 auto only drives in 4lo
- No power to the wheels and a horrible sound
- Another timing chain question
- Instrument Cluster
- Seafoam
- 93 4runner
- 22rte troubles
- Which Toyota do I have
- Size of 22-RE valve cover acorn nuts?
- 1991 DLX Xtra Cab 2WD Automatic -Starter Relay?
- My First 22RE, What should I do?
- 96 3.4L won't Start after battery short
- Idle dying/check engine light
- 1989 4X4 Pickup
- Change out Main Seal on 91 3.0
- '92 yota pickup no power
- 1988 Toyota Pickup V6 rough idle and runs rich
- 22R engine model and PCV valve
- Shock absorb-er questions
- 4 runner v6 3 liter wont start
- Please Help before I lose my mind!
- New 87 4runner owner from Nor Cal
- 1996 Taco rear-end in 2002?
- Ready to turn over, a dopey question so it belongs here
- Need to get my truck to pass smog! 84 22r pickup
- 89 yoda clutch trouble
- 3.4 engine near me
- 95 tacoma wont start... what did i do??
- need some tire help
- 0s2 harness location
- Squeak and Grease and quiet
- Clutch bleeding (I'm embarrased to ask)
- No AC 93 pickup
- Brake master cylinder ?
- Cooling Fan
- 5th gen gauge cluster removal
- Found a 85 turbo diesel
- Transmisson Issues
- bought a project 94 4runner. need advise
- How to Clean your Spark Plug Holes
- Cleaning the tank, any vehicle anyway
- another noob bumper question
- Body lift steering extension
- Toyota flatbeds
- Supra a340e splines vs AW4
- 85 toyota light frame rust should i be concerned?
- 91 4Runner sunroof slows near closing
- newbie: Need help with starting issue and CEL P0336
- Help a guy i wheelchair :)
- 30-40LE vs. 30-43LE
- Sas 1991 3rz swap problems
- A340E, what parts for a 4wd conversion
- 2KD bellhousing
- A340E t-case adapter
- A340E -> 4wd
- Help with '87 4Runner add a leaf fittment
- Spark plugs
- Need some help, Please
- intermittent clicking or rattling noise while in gear
- Front Interior dome light not working
- Front Parking Brake Cable Assembly
- used to have ac
- 86 22re Exhaust gasket stuck, fused to header - best option to proceed?
- engine swap
- no fuel
- 83 trans noise
- Price check on a 1989 4Runner
- advice needed: bad alt, leaky crank seal
- 91 3.0 Idle to low
- 3vze No start issues 1990 help!
- Best Zuk MOD Over or in Bump stop
- 89 4runner 3.0 help Please
- A glass issue, any experts, anyone seen this?
- Overdrive Comes On Early '85 LB EFI auto 4x4
- 3VZE Valve Shim removal
- plz help rear drum conundrum "dueo servo" brakes
- alignment and driving safety
- Quick help: c-clip
- 20r vs 22r
- wiring
- 94 toyota pickup code 21
- Gears
- 82 pick up Need Help OVERHEATING
- Fuel Economy Upgrade
- plastic radiator oulet rough mold,mold line off
- '88 22re Consuming Oil
- Fair price for a '91 pickup with 215k miles?
- lost body lift instrucations
- 3-VZE, is it worth keeping?
- Hard starting 3.0 4runner.
- 3vze oil pump
- 1994 Toyota Pickup 2wd torsion bar
- Intermittent NO start.
- Longbed 2nd vs. 3rd gen
- 86 22r spits, sputters, and smokes once warmed up. but runs good when cold?
- 86 22r idle and vacume
- '94 22re 4x4 5peed will 86-88 Tranny fit?
- 95 Toyota 4Runner won't start
- 95 4runner Manual transmission removal - freeze plugs
- What gasket is this?!?
- Denso knock sensors any good for 2nd gen 3vze?
- Electric fan problems
- 5vzfe conversion in california
- 1st time 22re rebuild
- Passenger power window problems
- 1991 4runner 3.0 that the efi fuse keeps blowing.
- VSS question, I feel like a noob... because I am.
- 4th Gen Pickup AC Question
- grill swap? 95.5- 97 tacoma
- For the newbies(and those smarter than the rest of us)
- Common 3VZE fuel issues?
- Air Diverter Valve
- Help me: 93 3.0 no spark and no power to fuel pump
- No pedal pressure after clutch replacement
- 95 4runner 3.0 engine swap question...
- Late model 22re upper plenum & TH to 85 22re?
- 94 4Runner 3.0 V-6 will not start and strange tap sound from airflow meter
- 95 4runner 3.0 Coolant leaks
- 1996 Tacoma losing power on any incline and loss of mpg
- Shopping for a yoga
- T100 transmission cooler lines
- My first 22re head gasket job
- 2002 4runner cross cable boost
- Exhaust leak
- rear window problem (not the wiper or lock button)
- 89 4wd v6
- 4 runner lacks power! help
- 87 2wd pickup losing brake fluid, but good pedal
- 22RE Lurches & Bucks Like a Stallion
- Radiator for 3.0L
- New Strange Sound when downshifting w/ video
- 3rd gen 4WD - picture of operation instructions?
- 94 rear suspension upgrade - questions
- 94 Toyota pickup 2wd front hub remove help
- Clutch Master Cylinder/Slave?
- 1991 v6 3.0 oil pressure
- Torsion bar lowering
- 3.0 egr
- 22re crankshaft bolt stuck
- 99 4runner, to fix or not to fix - seems stuck in 4 lo
- transfer case swap/ removal question
- 97 tacoma grill
- Heat guage says truck isn't heating up - '95 22RE
- No power after an injection pump swap on a 1985/6 diesel 2.4 pickup
- 22re running rich
- 84 toyota
- lift
- question bout transmisson swap
- 86 pick up 22r will not start in the am without starting fluid.
- It's a newbie disassembly question Help..
- 1995 4Runner door locks
- 2010 TRD off road prerunner carbon fiber hood.
- lockers up front
- 95 runner, v6 head gasket
- My 22r wonr start
- Idler Arm FA5040 Mythical creature....
- I thought it was some kind of filter till I cleaned the gunk off
- Oil Light comes on.
- dwell tachometer, HELP? what do you recomend?
- help buying a pickup 4x4
- To build or buy? 1st gen 4runner
- 22re Engine Replacement Reference Guide or Checklist?
- 84 pickup front diff removal
- 22RE poor accel. hesitation at operating temp AFM help
- What to do (88 4x4 and 95 4runner)
- 1987 Toyota Pickup Camper Shell on 87 4runner
- need help engine swap gone bad
- Hello to all
- 88 22re intermittent no start
- 1000rpm idle surge caused from brake lights
- where to find Idler arm FA 5040
- 4runner tires?
- power steering hose clamp
- could relly use some insight.
- ADD issue bypass?
- 82 4x4 pickup 22r overheating issues
- 85 22r carb flat spot and timing problem
- 1995 4Runner won't start
- Can I still use this Timing Cover?
- 89 hilux 2WD swap to 4X4 sas
- Tire size
- 93 Toyota 3.0L v6 pickup suspension help!!
- 3.0 broken egr valve delete.
- Bought a 4runner with a swapped motor, now need to replace the radiator
- Zuk lift
- Off road advice
- Best spark plugs for a stock 1990 4Runner
- 94 ifs steering stabilizer shock
- Help me lift my 81 SAS 4x4
- '82 shackle issues
- Am I ready for a front/rear differential swap?
- How do i post stuff forsale?
- front shaft issues
- window track sticks
- TRANSFER CASE (slipping/regearing) QUESTIONS
- Hello Everyone
- Anyone have any input
- E Brake Cable
- Need advice please
- 91 4Runner lift??????
- 98 4runner valve cover
- 33x12.50 or 35x12.50 with 4'' lift?? (pics)
- most lift from shackles alone?
- 1988 4RUNNER Power issues....DD need HELP FAST
- Need help with W56 snap rings. Rookie mistake.
- Nasty noise with 4WD disengaged, engaged=no noise
- Would this cause my rough idle?
- Tundra or Tacoma
- Supra Irs conversion on 1988 4x4 truck
- Just saying hello
- Factory 4.88 with a detroit?
- power problems think its my distributor any help thanks
- Gear ratio
- Current draw at idle
- thermostat gauge and overheating
- Anybody wanna help out a Yotatech newbie?
- Removing the bed.
- high mileage tundra
- What type of lock cylinder is this? 1977 pickup tool box accessory
- to SAS or not...that is the question
- Air Control Valve- Power steering pump
- Needs some advice on engine swap
- 2002 Toyota 4runner 3.4l 5VZFE
- Check-Engine-Light (CEL) code, how to read for Toyota Landcruiser 2002 GXV HDJ100R ?
- White Smoke from Exhaust, how worried should I be?
- Spool or lunch box style
- Jumper on AFM board
- Fuse or blower motor
- 2003 4runner 4x4 not engaging
- 97 4runner steering wheel upgrade
- URD 7th injector issues on T100
- 94 toyota pickup temp gauge pegged
- Need some help getting back on the road
- 350 or 4.3 swap
- amsguage electric fuel pump
- Handy tailgate motor info
- 3.0 runs great until it gets warm then it quits
- Halo headlights
- 1995 four runner 3.0 v-6 will 22re fit?
- Getting to wits' end with this brake thumping
- 1992 Toyota Truck Fuel Pump not running unless jumped
- Toyota Shifts Hard
- 4wdTranny from 93 truck to 91 4wd runner....a340h, will it work?
- looking to buy a 82 pickup, got toyota bug back! what to look for?
- Water with oil mixture HEADGASKET! HELP!!!
- Project Pickle ...EGR crossover ..need opinion
- Just another Surging Idle Thread
- Newbie With a 91 4wd 4Runner no vaccum line to vsv's
