PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. Just got my new beater 4runner looked at by the dealer, and he quoted me:
  2. Piston ring install help
  3. Where to begin...hmmmm
  4. Ball Joint lift vs Body lift vs SAS
  5. Will a 1985 4runner frame work under an '86?
  6. Seat sawp
  7. 85 4 runner lift, high steer???
  8. Huge pool of oil under intake manifold - 3vze
  9. 22RE almost done. Swap in a different motor or stay 22re?
  10. What is this?
  11. Are hub Covers available?
  12. 96 seats in 85 4runner??
  13. 90s 4runner, 44s DC FCs and SAS swap questions
  14. New to Yotatech
  15. 1987 toyo pickup ifs want to switch to sas?
  16. Rear wheel bearing loose in backing plate.
  17. Crankshaft Keyway Worn - Suggestions?
  18. Alright, how the heck do I get my rotors off?
  19. 94 Pickup DLX A/C question
  20. 91 toyota 4 runner stuck in park pleas help
  21. Valve Ajustment Tools Help!
  22. Parasitic Battery Drain
  23. what kind of 54mm or 2 1/8 socket do I need?
  24. POR-15 questions...
  25. truck dies after idle and warm up
  26. Gasket diagram
  27. What is backspacing?
  28. Body swap: 81 truck on to 99 Tacoma frame
  29. Finding TDC ?
  30. My '90 22re wont start
  31. birfield joint
  32. differential leaking
  33. u bolts grade 5
  34. Sell or keep?
  35. distributor question
  36. Serious break drag
  37. Brake Light Comes On
  38. W trans questions
  39. 06 4runner brake rotor removal?
  40. Bending, without bender?
  41. FJ80 3fe...no compression
  42. skid plate bolt size
  43. truck wont start
  44. Would this be an alternator problem?
  45. Convert grille 86' to 80'-83'
  46. Rebuilding 3.0 top end
  47. Clutch Fork stop?
  48. Need Advice: 1989 toyota pickup 22re Cam/head issues
  49. Advice needed!! 88 4runner roll over damage-fix it or?
  50. Large oil leak after long drive. 3vze
  51. Front Disc brake replacement Help
  52. Laws in Arizona reguarding mud flaps and wide tires on 4runner
  53. Unidentifiable Dashboard Button?
  54. Rear Axle work
  55. starter rebuild kit
  56. 93 22re into an 83
  57. Help my Truck CLUNKS and I don't know why
  58. Proper and only right way to tune a Weber 32/36
  59. weber help to lean
  60. Hot Start
  61. How do I install shocks?
  62. 87 yota 22re injector problem please help
  63. 80's toyota axle or D 44 for SAS? Need advice
  64. Help me choose a lift! '96 4Runner
  65. 2004 Highlander
  66. Year to Year question
  67. 2wd towing question
  68. is there any more mods for an 84 with a 22r
  69. Upper Intake Manifold Tubes
  70. Never owned a 4Runner questions?
  71. My 1995 toyota 4runner wont turn over!
  72. temp gauge isn't working...universal leaks. 87 4runner
  73. 86' 4x4 Fuel line replacement
  74. 91 4Runner 3vz v6 4x4 identify wire
  75. Clutch Pedal issue
  76. 86 4runner sr5 turbo vs. 89 xtrcab SR5 4x4
  77. keyless entry remote
  78. Replacing head gaskets on a 1995 4runner sr5 3vze
  79. valve cover bolt issue
  80. 2nd Gen 4runner Exhuast Parts
  81. First Toyota Truck..what to improve?
  82. Regearing??
  83. Rear drive shaft locking up on me
  84. The great bull bar hunt.
  85. Thinking about a Locker need Information
  86. Drive shaft? Where did it go?
  87. 85 yota truck, carb problems
  88. Backfire between gears
  89. wire recommendation for reciever winch
  90. pumping brakes causes missing
  91. performance for my 84
  92. 86' Carb Rebuild
  93. 2" Lift Questions! New truck
  94. Looking for bolt size on manual transmission fill plug...
  95. Maunal Locking Hub Installation Difficulty
  96. Question on factory straight front axle
  97. Oil Change - US Quarts or Imperial Quarts - Help
  98. advice
  99. Celica 22re into my 4runner. Looking for info.
  100. 1986 Toyota 4x4 resemble's???
  101. 86 needs lockers!
  102. Having issues with my 88 pickup
  103. Heli Coil usage
  104. Jeep Coils Fit our trucks :)
  105. Replacement hoses
  106. 86 pickup 5 speed tranny sloppy shifter
  107. Vehicle Speed Sensor
  108. how much clearance does 33s + bj lift net?
  109. Another lift kit thread- searched and didnt find what i was lookin for
  110. 03 celica sunroof stuck open
  111. what trans is in my 90 4runner?
  112. Rear coil springs. Yes or no?
  113. 98 4Runner temp gauge
  114. Axle Buildup Questions
  115. snorkel modifications!! need some ideas
  116. 86 Truck-new to Toyota lots of questions
  117. 22r vibration
  118. Need Access to 93 Toyota Pickup Knock Sensor Connector/Pigtail
  119. Engine paint recomendations
  120. 1990 pickup w/ rough idle and dies... need some help thanks
  121. Engine swap
  122. which car/truck has direct bolt bucket seats to put in a 89 single cab p/u
  123. whats gears will make me faster with 31 -10.5 -15 tires
  124. 4Runner Engine Swap questions 1989 to 1985
  125. BOLTing on a receiver
  126. Toyota Truck, Clutch and Flywheel interchangeability?
  127. fj40 or fj60 build?
  128. TRD hood
  129. 1986 toyota 4runner
  130. Grinding noise turning steering wheel full
  131. Timing Belt/ Water Pump Price Check
  132. buy/sell/trade section?
  133. I can't fix it!!!! 1993 4runner is haunted
  134. Question about SPACERS/ correct size etc.
  135. Need Bumper and Wheel Advice, '94 Xcab
  136. replace rod bearings without removing the engine?
  137. Vibration
  138. Pics of hood vents?
  139. Upgrading a stock height rear on an 86... (w/ marlin stuff?)
  140. 3vze Timing is way advanced
  141. 5 speed tranny???
  142. radiator question
  143. Tires and tint
  144. Won't start! Air, fuel, spark, help!
  145. 92 4Runner engine clicking/knocking.
  146. IFS elocker?
  147. Engine swap on an 84 4runner
  148. What year is this 22r
  149. What to mod on my new 4runner 1986 all stock
  150. Rims and tires??
  151. Brake Job
  152. valve spring
  153. quick question about SAS using FJ40 axle on 89 runner
  154. Best preformance/fuel economy upgrades?
  155. 92 4runner engine sound, Sounds like a baseball card in bicycle spokes
  156. 90 pickup towdolly
  157. Solve the mystery! Why wont my Runner Start when warm?
  158. Truck starts runs, starts runs dies quickly, rinse and repeatAs for the truck, I know
  159. 3rd Gen Suspension/Lift Questions
  160. Replacing rear shocks
  161. 22r valve adjustment
  162. 95 4Runner questions
  163. How do I remove parking brake from back brake drum? '84 Pickup
  164. 92 4runner 4cyl questions
  165. 95 4Runner 2nd Gen mod ideas
  166. BJ spacers on craigslist, anyone try them?
  167. Bilstein/RCD 5100 Adjustable
  168. need advice on removing top
  169. Rear Spring Shackles and Leafs
  170. 2nd gen 4Runner use Tacoma manual hubs?
  171. 80 CA pickup stalls on deceleraion
  172. blocks or shackles?
  173. clutch pedal shake
  174. Pinion Bearing replacement?
  175. Just a quick carburetor-related question...
  176. 20/22r question....
  177. IFS or SAS?
  178. Removing the rear bumber on my 86 4Runner
  179. Which bolts for bellhousing to engine?
  180. 1985 PU G52 Trans Fill Plug = Reverse Switch ?
  181. procomp steering stabalizer
  182. Header on a 22r
  183. Will I cause damage driving with broken 4x4?
  184. standard cab to xtracab 96 tacoma
  185. my tires and shocks are toast!
  186. suppenion lift kit?
  187. can a new 02 sens.burn up by not resetting computer
  188. shifter fork retainer pins
  189. 93' 3vze overheating immediately after radiator flush
  190. what size tires 33" or 35"???
  191. Help on a little black wire?!
  192. Another A/C Question
  193. Factory Lift
  194. will a 1985 22re work in my 22r 1989 pickup?
  195. Ok to drive a short distance with broken shock mount? Shock selection advice
  196. Economy sas build?
  197. OEM parts online?
  198. tire size
  199. 98 4Runner - Will a 2" body lift clear 285s?
  200. how bad of a fix is a leaking transfer case?
  201. 4runner gas tank swap 22re into v6
  202. 1991 Toyota pickup - do I need a rear bumper in PA?
  203. First 4Runner - Needs Height Adjustment
  204. Gears
  205. Nursing my 2nd gen 4Runner along?
  206. Engine size
  207. 1986 Toyota xtra cab roll bar size?
  208. 86 yoda 350 swap
  209. overheating/power lost
  210. 1997 4runner wont start
  211. lifted 89 pickup cv axle problem
  212. 87 4runner won't start
  213. '90 3vze water pump scorched, block scorched
  214. flange bolt, center support bearing
  215. 88' toyota pickup lift?
  216. Spark plug wire differences... *thin vs thick*
  217. Lower control arm/bushing replacement Question
  218. 1991 Toyota Four wheel drive, Gear ratio
  219. No experience with clutch question
  220. Sealant for left rear quater glass?
  221. u-bolt flip plates
  222. 4.56 richmond gear ?
  223. 22RE header sources?
  224. Auto transmission/torque converter help
  225. 86 xtra cab bucket seats to 89-95 bench seat swap fit?
  226. How to modify MAF *with pics*
  227. need help with alternator/wiring problem
  228. Suggestions on a front bumper or winch mount.
  229. roll cage time... ideas plz
  230. '90 4Runner slow acceleration - normal
  231. Improving off road performance
  232. spring compressor alternatives?
  233. Will 34in tires fit with 3in lift?
  234. AC to Onboard Air conversion... couple quick qustions
  235. Front Power Windows stopped working After adjusting with power mirror!!
  236. front axles seal replacement
  237. Fuse Box Location?
  238. Cannot Identify Motor - turns out to be 3.0
  239. "Fiberglass bed brackets?
  240. How to modify MAF for 3.0
  241. Body lift advice 2WD 95' 4Runner Automatic
  242. Brand Newbie.....
  243. Lockers?
  244. Idle problem with a 92 yota pickup!
  245. i'm still sagging
  246. Bed bracket/mount Source?
  247. 97 Radio and turn signals do not work
  248. stock 4.56 gears?
  249. knock sensor wire cut and no code thrown
  250. 88 4runner v6 lift suggestions
