Sponsored by: CARiD
pumping brakes causes missing
Old Aug 23, 2011 | 06:55 PM
tommygirl's Avatar
im confused cant figure this one out i can start the truck barely mash the brake miss,miss, then stops press all the way down fine let off the brake miss,miss then if i pump the brakes it misses bad changed brake booster 3 times same thing changed check valve same thing changed egr vacuum modulator same thing sprayed ether on all vacuum hose around carburater bottom cant find no vacuum leaks. so i cant figure it out could it not be getting enough vacuum if so how do i know how much its suppose to get to check it ,and if it isnt getting enough vacuum how can i fix that. it is a 1986 toyota 4x4 22r thanks for all the advice in advance
Old Aug 23, 2011 | 07:27 PM
xxxtreme22r's Avatar
spray carb cleaner in and around the carb base gasket? I know you said you hit the hoses but.....
Old Aug 24, 2011 | 09:56 AM
tommygirl's Avatar
i have tried spraying at carb bottom when i sprayed hoses hoses no changes
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Jonny246
Jul 12, 2015 04:51 AM
