Sponsored by: CARiD
Hot Start
Old Aug 29, 2011 | 10:54 AM
Toytoter's Avatar
Hot Start
ok guy's i have a 89 4x4 22re, new engine, it has a starting problem when it is hot. in the mornings at cool morning temps it starts great. Drive it an hour to work turn it off wait 5 minutes starts fine. wait an hour it has to roll over alot and then starts but runs fine. For the rest of the day it does this, after it starts it's fine, cut it off it start's right up until after a while and you have to grind on it. As per the factory repair manual i replaced the green temp sensor and the cold start injector timeout switch, no change. Oyea, if you roll start it, it will fire right up. Any ideas?
Old Aug 29, 2011 | 12:24 PM
4Crawler's Avatar
Try this:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Aug 29, 2011 | 12:49 PM
ChefYota4x4's Avatar
Originally Posted by 4Crawler
Hey, welcome to Yotatech, first off.... Secondly, FOLLOW THESE INSTRUCTIONS TO THE TEE! ^^^^
Old Aug 30, 2011 | 06:19 AM
Toytoter's Avatar
gotcha i will, i saw this diagram in my book but have not had a chance to go through it yet i will get on it next. Several people have told me to clean all of the electrial connections good before starting troubleshooting, as soon as i finish that i'll get on this THANKS
Old Aug 30, 2011 | 09:01 AM
Gotcha, . I hear ya, ...and that's good advice on cleaning up those connections. Might try a dab of dielectric grease on most of them after you clean them up.
However, reading your post again.... I just noticed, "Oyea, if you roll start it, it will fire right up. Any ideas?".... Did you add that later? DANG, if not, I'm slipping! lol. (Maybe 4crawler, reading that portion, felt it's still likely a 'fuel delivery during hot soak' situation.)>>
If the AFM, C.O.R., etc., check out, .... then we can go from there.
Happy Gremlin Hunting, wish you quick success! lol.
Old Aug 30, 2011 | 09:10 AM
Toytoter's Avatar
No, i had it in the origanil post, I'm alway's going to give all of the info that i have so that you can know what i know. I work in the reasearch business and i hate incomplete info. The best way to get real help is to help others see what you see, plus i don't wan't you guys to waste you time. that way we can get to somebody elses problem.
Old Aug 30, 2011 | 01:30 PM
OrRunner's Avatar
watching this thread toytoter, I have the same exact to a tee problem as you in my 87 runner. However I have not got ahold of a mulitimeter yet to test my Cold start time switch or the temp switch from the TSB. Check out my thread there is some good info from Bob, but it looks like you have ruled both of these items out:
https://www.yotatech.com/forums/f116...rm-hot-239837/
If I find any solution, I will let you know as well. For some reason I keep thinking its my fuel pump since you have to almost prime the fuel system to get it to start hot, Does yours do this?
Old Aug 30, 2011 | 01:33 PM
4Crawler's Avatar
Try the fuel pump test jumper, takes a minute, costs nothing and if it helps, that points you to the cause of the problem.
Old Aug 31, 2011 | 10:51 AM
Toytoter's Avatar
Ok, got through with the cleaning of the connecters and used dielectric grease on them and tried the fuel pump jumper twice and there is no change. Gonna check the AFM and the C.O.R. next. THANKS GUY'S!
Old Aug 31, 2011 | 11:18 AM
OrRunner's Avatar
curious as to your outcome...Let us know what you find!
BTW the COR should be audible when turning the truck over, You will hear a click type sound. I am pretty sure this indicates that it is functioning, but at what level is beyond me...maybe someone else can explain better?
Old Aug 31, 2011 | 11:28 AM
Toytoter's Avatar
Yea ChefYota gave me some stuff to do testing those 2 things and i will let ya'll know what i find.
Old Aug 31, 2011 | 11:49 AM
OrRunner's Avatar
sounds good man, I am updating my thread with what I find if you want to check in on it. Just found some good resistance values for the AFM on 4crawlers site. Thats my next step....Good luck man!
Old Aug 31, 2011 | 11:59 AM
Toytoter's Avatar
HAHA thats funny I was there too, I found that same site and was looking at it when I got notice that you replied. Good luck to you too.
Old Sep 20, 2011 | 05:17 AM
Toytoter's Avatar
Sorry it's been so long but i've been real busy at work, this is what i've found out so far, the cold start injector sprays while the switch is in the start position and does so until you return to the on position. during these times when it is hard to start it calls for the cold start injector to spray. the fuel pump runs fine also. i'm going to try unplugging the cold start injector when it is hot to see if the thing is flooding. i'lkl get back.
bigjstang
Jun 2, 2025 03:56 PM
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
HRDC0R19
Jul 5, 2015 06:43 PM
