Sponsored by: CARiD
80 CA pickup stalls on deceleraion
Old Aug 8, 2011 | 09:36 AM
4serge's Avatar
Hello, this is my first post here. I bought 1980 Toyota pickup which have not run for 2 years. The fuel pump was defunct, I replaced it and had all vacuum lines connected in accord with diagram on the hood. It is CA version. One hell of the carburetor I must say
Now, I have to have it smogged and I have two issues.
First if I adjust idle to 900 rpm it goes in waves - rpm rises up then drops then rises up again.
Second, when driving it stalls upon deceleration - I have to heel-and-toe it all the time..
any advice on this ? also, any advice on good shops in Sacramento area capable to smog carb yotas would be appreciated... I understand that I have to keep the stock carb to pass CA smog ?
PS I do not see much change when I mess with a mixture screw, so I set it up to default 1 and 1/2 turns out.
Thanks and please let me know if this is the wrong forum to ask these questions..
serge
Old Aug 8, 2011 | 11:15 AM
Jasper 83's Avatar
You have to get a 1980 pickup smogged!? I would consider moving to another state and buying a new carb haha...just jokin. I would check your vacuum lines again and just make sure you didn't miss anything. It sounds like you might have a vacuum leak somewhere.
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Jnkml
Jul 6, 2015 01:20 PM
