Sponsored by: CARiD
86' Carb Rebuild
Old Aug 23, 2011 | 05:48 PM
1558smitty's Avatar
Carb rubber spacer
I recently removed my 22R carb to rebuild it, I noticed that there is a rubber spacer between the carb and the intake manifold...my question is what is that part called and does the gaskets that go between the boot and the carb and the boot and the intake manifold come with the rebuild kit. Also I bought a carb mounting gasket but it doesn't look like it fits anywhere on the carb.
Old Aug 23, 2011 | 05:51 PM
xxxtreme22r's Avatar
the gaskets will come with it, but not that spacer. And if you got that carb mounting gasket from somewhere like autozone, it's not for the carb at all, it's for the "fuel heater" under in intake manifold.
Old Aug 23, 2011 | 06:03 PM
1558smitty's Avatar
http://contentinfo.autozone.com/znet...-615B/image/4/
So the two middle gaskets in this picture are the ones that go between the rubber boot and the intake manifold and the rubber boot and the carb??
Old Aug 23, 2011 | 06:10 PM
IIRC no, those two wouldn't be used, I think they might be for a 20r. The upper and lower ones. I can't remember which one is the top gasket or the bottom gasket off hand. It's been awhile since I had the aisin on mine.
Old Aug 24, 2011 | 04:19 AM
1558smitty's Avatar
Carb phenolic insulator
I am trying to locate the correct gaskets for the phenolic insulator, I need to know if the gaskets between the phenolic insulator and the intake manifold and the actual carb and the phenolic insulator are in fact in the carb rebuild kit, here is a picture of the kit I purchased, please someone tell me if the gaskets I need for the phenolic insulator are the kit I purchased, if not where can I find these gaskets at??
Old Aug 24, 2011 | 05:00 AM
Sensei's Avatar
Looking at the picture, the second and third rectangular gaskets from the top with the circular plenum holes are the gaskets for the insulator.
Old Aug 24, 2011 | 08:54 AM
JamesD's Avatar
I have a new OEM Toyota one and the gasket is glued to the spacer. If you need this part, PM me.
James
Old Aug 24, 2011 | 09:27 AM
Fink's Avatar
I merged the two threads that you had on this.
Fink
Old Aug 24, 2011 | 10:22 AM
83's Avatar
83
Like JamesD said, the new ones from the dealership come with gaskets glued on. Really, the dealership is the first place to look for most parts, unless you have another OEM parts source. Be careful of auto part stores.
Old Aug 24, 2011 | 05:31 PM
1558smitty's Avatar
86' Carb Rebuild
I am currently rebuilding my 22r 2bl Aisan Carb and am coming to find that all the screw are rusted and or stripped, so basically I am needing to get a new screw set to go along with my rebuild kit, does anyone know where I can find a screw or fastener set????
Old Aug 24, 2011 | 05:34 PM
1558smitty's Avatar
Aisan Carb Electric Choke removal
I currently have two original Aisan carbs, one of my electric chokes looks like its been riveted in and the other has screws, the one I am rebuilding is rivited and I had to remove the butterfly to slide the rod out, it feels like the rod inside the choke that connects to the butterfly isnt seated in there properly anymore...did I screw the electric choke up or will it be alright???
Old Aug 25, 2011 | 12:49 PM
85TurboRunner's Avatar
you need to drill the rivets. The one you have that has screws has probably been taken apart before.
Old Aug 26, 2011 | 08:32 AM
1558smitty's Avatar
Aisan Carburetor Electric Choke
The electric choke on my Aisan carb has went out and need to replace it, does anyone know where I can get one at???? Any replacements parts (screws, bolts) for that matter???
Old Sep 3, 2011 | 11:49 AM
1558smitty's Avatar
22r Aisin Electric Choke
The electric choke on my stock carburetor went bad and I took it off to try and replace it, and now I cannot figure out how the butterfly arm goes into the spring coil and how its supposed to be wound up, I am stuck on how to get it back the way it was, it is taking forever to start now and when it does it will only run for about 10 seconds before starving out, please help If the electric choke isnt installed properly will that affect the running of the truck in regards to my truck having trouble starting?
Old Sep 26, 2011 | 02:02 PM
konaman's Avatar
My electric choke stopped working too so I installed a hand choke for $10 and took all of 20min.
Longbed 90
Mar 11, 2019 12:38 PM
4.34runner88
Feb 7, 2016 02:24 AM
bhaithc
Sep 17, 2015 07:53 PM
Kylenicoll33
Sep 17, 2015 08:40 AM
--Oz--
Sep 6, 2015 01:06 AM
