Sponsored by: CARiD
22r vibration
Old Aug 20, 2011 | 04:38 PM
johngdeere's Avatar
Thumbs down 22r vibration
i have a 1986 yota pick up 4x4 five speed has a vibration at an idle and up the rpm range vibrats the seets dash floor stering weel althow wile driving on highway at 60 - 65 it is smoth runs good new plugs wires carb is cleen timing 10 dgr first yota ? dont have a clue
Old Aug 21, 2011 | 09:23 AM
mikes451's Avatar
Timing on the 22r carbed version is 0 degrees, with hoses on diaphrams on distributor plugged.
Old Aug 21, 2011 | 04:25 PM
johngdeere's Avatar
i seet it 10 degrees with hose off when u on hook the vaccum it idles down when u plug it in it idles up i dont under stand y it has two vaccum lines on distributor
Old Aug 21, 2011 | 04:46 PM
xxxtreme22r's Avatar
0 degrees when idle is less then 750-800 RPM, with he hoses plugged, if engine idle goes up when putting the lines on, there is a possibility that the diaphram inside the distributor is busted and is causing a vacuum leak. Once you put the hose back on your timing should be around 14-15 degrees IIRC, if the tiiming does not advance with the hoses on, then it's a problem with the diaphram.
FYI the back diaphram is for cold timing advance and the rear is for normal operating temp. Always check timing when warm. Only one of those lines should have vacuum at a time.
Vibration can be anything, could be engine mounts, u-joints, transfer case mount, transfer case output shaft, rear diff flange, driveshaft loose and probably some others in the drivetrain I have missed. Since it goes away while crousing on the highway, I don't think it would be ball joints, tie rod ends, idler arm or anything steering related.
buckz6319
Aug 5, 2017 03:50 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
