Sponsored by: CARiD
advice
Old Aug 22, 2011 | 05:59 PM
Chaug09's Avatar
Question advice
should i rebuild and add mods to my 22re or put somethin bigger and better in? any advice/opinions is appreciated thanks guys
Old Aug 22, 2011 | 06:17 PM
rattlers's Avatar
I would rebuild the 22re
Old Aug 22, 2011 | 09:00 PM
87 Deathtrap's Avatar
What do you plan to use it for? What are your plans for tires/gears etc?
By default, I would lean toward rebuilding the 22re as well, its always been enough for me, unless a 3.4L conversion is in the budget.
Old Aug 22, 2011 | 09:11 PM
chosenchange's Avatar
22res are solid and with the right gearing push most any 35 around. IF your not wheeling I back the 3.4 swap well i guess even if you are wheeling i would but the money needs to be there. Though i saw that guy who put the 300sd Mercedes motor in and that was pretty slick. More info does help with the advise how much off road, on road ultimate goal, any concerns to gas mileage and budget all are a factor for sure
Old Aug 22, 2011 | 09:24 PM
toyota4x4907's Avatar
Rebuilding and "modding" would probably be the most cost effective. These are simple, strong engines. You could get away with rebuilding, bore, new street performance head (P&P, over-sized valves), header and decent exhaust for under $2K. Probably more like $1200-1500.
ANY swap is going to be at least $2K. MOST LIKELY more. Plus, its fun to tell people "yeah..no its just a 4 cylinder "
ashamsuddin
17
Jul 22, 2024 03:59 AM
Steven.m.paulk
Jun 7, 2020 10:45 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
charlie_fong
Sep 27, 2015 10:06 PM
taraf
Sep 25, 2015 02:57 PM
