91 toyota 4 runner stuck in park pleas help
i parked my 4 runner and now it is stuck in park i did some reading and it sounds like it is a fuse that blew i had a trailer hook up to it i was wiring the truck and trailer... but i cant find where the fuse is... pleas help
My '95 4runner used to do this alot, however, it wasn't a fuse, it was the shift lock override. I'm not saying it isn't a fuse, but give this a shot if you can't find a blown one. Near your shifter there should be a small plug that you can pry off with a key. With the truck started, insert a spare key into the hole under the plug as you press the shifter button and pull back on the shifter. I hope this fixes your problem.
AustinTaco
06-21-2015 09:54 AM
