what size tires 33" or 35"???
i have a 1991 toyota pickup v6 3.0l with a 5 speed manual trans,3" body lift and 1.5" bj spacers and blocks.Im currently finishing installing 4.88 gears i got from the jy.i did search on here and generally every one is saying 4.88 with 33" tires but i live in the pa mountains and i go up this steep hill to work and with bald 33' tires it is at like 3500 in 3rd or lugging in 4th.im just looking for some opinions to whether i should let it sit at 3500 everyday when i go up the hill or should i move to 35" tires to bring the rpms down in 3rd?
the only reason i am even debating it is because i ran it up the same hill with the same tires and 4.10 gears and it went up better although i was in 3rd gear seems 4th and 5th are more like overdrive gears
no more than 3k,ill probably go with 33"s hopefully the rpms will drop a little in 3rd once i get new tires or ill just have to slow down on that hill.I did notice on the highway i was running 3k at appr.70-75mph but my speedo may be off
Do 35s!! With your amount of lift you could fit them. I got new 33s and recently installed v6 4.88s and now my 33s look puney
. Id imagine with 4:88s & 35s it will feel alot like my 4.10s & 33s did. My rpms are alot higher with the new gears, now, i kinda liked the lower rpms of the old ones. The only advantage I feel is a lower 1st gear.
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
