Sponsored by: CARiD
"Fiberglass bed brackets?
Old Jul 24, 2011 | 05:14 PM
IamJake0117's Avatar
I have a 84 toyota pickup ext cab lots of engine work done new trans and cab is solid box however is toast. I have a fiberglass box i found on craigslist picked it up got it all preped and realized i need mounting brackets to attach it from the metal frame to the box anyone have the 4 brackets know, know where i could get them, or any suggestions on how to make them? thanks
-Jake
Old Jul 24, 2011 | 05:21 PM
streetlancer's Avatar
Pics would help, but theres a guy here who specializes on toyota fiberglass. Maybe he could help.
http://www.toyotafiberglass.com/
Old Jul 24, 2011 | 05:27 PM
Well my truck still has the rusted box on because i dont wanna take it off and not have the brackets to finish the job. however what i can do is describe the problem to a greater extent. The metal box thats on the truck has 4 brackets welded to the box that attach to the frame, I need to make up this gap because the fiberglass box doesnt have a gap between the bottom of the box and frame. I dont know if this helps describe it at all
but it may.
Old Jul 24, 2011 | 06:59 PM
4Crawler's Avatar
Are you talking about the bracket off the frame that the bed bolts down onto or the boxed supports under the bed?
If the frame brackets, there are 2 pair up front, one pair in the center (pictured below) and then in back the bed just bolts to the frame rail:
Old Jul 24, 2011 | 07:43 PM
Well I know I have a original Toyota fiberglass box and I need the spacer between the bottom of the fiberglass box and the frame which the Toyota fiberglass box bolts to the spacer and the spacer to the frame I picked the box up and didn't realise it didn't have them and didn't remember to
Old Jul 24, 2011 | 07:45 PM
Also Im sure a 4runner frame is different if that's what your refurring where they bolt..
Old Jul 24, 2011 | 08:07 PM
4Crawler's Avatar
Pickup and 4Runner frames are quite similar. Main difference is back of the 1st 3 pair of body/cab mounts. 4Runner will have 2 more pair of mounting brackets, pickup will have 4 more pair. Brackets weld to the frame then bed bolts to those. Picture above is the bed mount bracket and bolt by the rear wheel well.
Might give Corey at Toyota Fiberglass (http://www.toyotafiberglass.com/Truck.htm) a call and see if he has something that will work. Probably a good chance your bed came from there.
Old Jul 25, 2011 | 12:33 PM
Well thank you for your knowledge
Old Nov 25, 2011 | 05:08 PM
slacker's Avatar
he phoned me .. and I couldnt help .. sorry
it was NOT one of our beds and not sure on the " compeditors" mounting systems or "quality" of substructurs .. so I didnt even want to suggest as I woulnt know the outcome
sorry I couldnt help
maybe , If you could post some pics .. I might be able to help
zombie_stomp
Aug 17, 2015 05:29 PM
shisha1999
Aug 14, 2015 01:33 AM
snekysnake
Aug 13, 2015 02:46 AM
58rennur4
Aug 4, 2015 08:49 AM
mickyd9990
Jul 6, 2015 09:01 AM
