AC to Onboard Air conversion... couple quick qustions
so im trying to do some research, dont have much to spend (broke college student) but i want to keep progressing with my rig. so my plans are to try to do that onboard air through the ac pump which i already have on my 85 22re. im planning on just oiling it manually when i use it, but does this mean i have to drain the oil after? and how can i set it up so that i dont need to run i through i tank. i mainly just want to use it so i can air down on the trail and air back up when i get back on the street. any help would be appreciated. also, if there is a detailed thread that i havent found on how to do this without a tank that would be great too.
read up on this.
https://www.yotatech.com/forums/f31/.../#post51683279
i have some info on my build page pages 5&6 i think.
You'll have to put in a micro fogger to lube the pump.
Tofers thread is a good start on what to do to set your system up. I just recently put mine together based on his setup.
icentropy
Jul 14, 2015 10:23 AM
Jnkml
Jul 6, 2015 01:20 PM
22re, 4runner, ac, air, board, conditioner, conditioning, conversion, convert, converting, onboard, pump, toyota, yota, yotatech
