View Full Version : Newbie Tech Section
- Need some Advice on my project!
- 22RE Junkyard Engine - How does it look?
- Air bump stops...how to measure for them
- 32/36 DGEV or 38 DGES
- 2.7 liter smoking
- When exactly to replace Timing Chain
- Bed sizes/Camper shell question
- axle seals
- First Gen 4Runner Leaf Packs
- connecting rod rebuild cap-tastrophy.
- Shocks
- 1980 sr5 4x4- elocker compatiblity
- Battery for deep water fording
- setting tome after a head gasket job
- 2006 Tundra off road bumper????
- Body lift r&r to stock
- 1991 driverside cv axle replaxement
- Need help.: are 2013 tacoma TRD shocks compatible with 2008 4runner
- Help me identify this sensor ? on my 22re ...
- New waterpump gasket 2003 Tacoma
- New to Toyota trucks
- Simple LED wited to a switch --- Why won't it work?!
- Newbie with a question or two... go figure.
- two driveshaft questions
- '90 4Runner - No Rear Wiper Control?
- Questions about locker and spool for my D.D.
- Baja brush guard for 93 22re?
- 93 toyota pickup 3VZE distributor timing
- Cylinder head diagnostic help
- Changing front shocks in 1993 4runner
- Newbie Suspension Question
- overheating
- 1997 T100 auto Motor, wanting M/T Ecu
- Fault codes
- SuperCharger Questions and Problems
- 1999 T4R Hard Starting
- 22re, rear suspension. truck leans to one side?
- Timing Belt
- Error code 52?
- Engine Miss
- 3vze engine schematic
- where is the catalytic converter?
- 1992 22re pickup, reading codes with a test light??
- 1986 toyota won't start
- Question, Destroyed distributor
- Newbie Knowledge
- 1988 yota pickup driveshaft
- I need help, 22re Running bad
- 93 22re, head almost done, questions
- u joint noise
- Can someone confirm I have found the correct manuals and offer advice on any others?
- 94 4runner 3.0 HG question
- Timing Belt Advice and Concern
- how to replace timing cover gasket 93 yota pu 22re
- Cat Back on stock 22re-Power Gain?
- All metal radiators for 3rd gen 4Rs
- Blown HG 93p/u
- 22re timing noises/timing tensioner issues
- N00b ADD question
- 89 4runner lock cylinder "set" replacement
- '05 T4R tach, speedo non op
- idle and acceleration once gas pedal is pushed
- Oil pressure sensor...dumb.
- a Simple repair turns troublesome: 1990 4runner 22re
- 1st Gen Pickup?
- Fuel tank actually bone dry?
- 22re intake phlenum reaaly cold???
- 1997 T100 parts compatibility question
- driving without rear driveshaft
- Alternator Wire to Positive Terminal
- 1983 transmission help
- Vague Steering, too much play
- New owner of 2002 4Runner Pointers?
- broken drive shaft
- R150 shifter base
- Fuel problem? Need help
- 22RE died
- Need info to repack bearings and do brakes on 1 ton full floating rear axle & wheels
- Changed the Timing Belt, now the Engine is Knocking
- 1gen body swap?
- Choosing wheels
- Bargain buy, major headache?
- 85 4runner 22re idle and starting problem.
- Passenger side lean
- Lumpy Antifreeze?
- what gear ratio to use for 33's
- Good parts lookup sites?
- how do you ID a transmission?
- fuel injector resistance
- 1990 v6 3.0 4 runner
- engine wiring harness
- #6 cylinder skip
- 22re crankshaft removal
- Rear brake clunk.
- 85 Toyota 22RE 4wd EFI and fuel system question.
- con rod end cap markings
- Door Panel Swap??
- 81 window regulator
- New guy? 87 spits and sputters
- 95 3.0 NO Power Until 15 MPH
- 1987 toyota ifs width rear axle
- '91 Pickup - Clutch pedal engagement/adjustment issues
- Shock length for 4" lift springs?
- Number on radiator support 1984 truck
- 88 p/u: How to remove the cigarette lighter?
- jumped timing chain jumped poss. collusion?
- 86 toyota doesnt run for more then 3 seconds
- 2nd gen 4runner sag
- Looking for a 6 speed for my 85 4x4. Any ideas?
- What's the biggest lift I can do on my ifs?
- Tie rod trouble
- Where is the blower motor resistor located on a 2006 4runner?
- Asisn carb linkage.
- 91 4runner bumper bracket question
- carrier bearing
- long trip for 4runner
- New guy question, what year 4X4's are preferred?
- 22 R knocks when warm ?
- 1998 Toyota Tacoma overheating
- 83 toyota pickup dies on rough roads
- Hard to start stalls out...
- Limited slip or lockers for 1977 Toyota pickup?
- 1995 4runner fuel, spark not running
- soooo i need help: new to me 1988 Truck
- Over 4 inches an IFS requires straight axle?
- Fj40 needs p/s
- 94' Toyota 4x4 PU 3.0L idle issues! Newbie!
- 1984 4runner bumper- 2wd vs 4wd
- suspension lift for wifes t4r
- 22R start problems.
- 88 4wd,frozen vent, rear axle seal replacement ,bearing lubrication
- 4Runner lift kit on a pickup?
- 94 V6 Pickup intermittent starting issue
- alarm system killin my fuel
- Roof Rack MPG loss
- 1991 4runner replacing water pump and p/s pump and am stuck
- Hubs?
- Looking for more flex
- cam / rocker arm fail.
- Tire size for an 88 p/u etx cab
- Engine swap--Fits what years??
- cor
- 83 toyota Pickup
- V6 no spark help
- Exhaust
- '84 4runner suspension
- Gearing
- 1.5" BJ spacer breaking shocks?
- heater core??
- Cold start high idle?
- 4wh or 4wl
- 87 4runner 22re wont idle right after rebuild
- Will a K-662-38 Weber car work on my 22r?
- Could some one answer my ?
- Need help 1995 4runner Front differential sensor
- can you do it?
- Hi and a couple of questions
- wont pass smog
- gas tank minor issue
- 93 3vze 4X4 SR5 Low Idle For 30 seconds
- Looking at buying 90 yota
- need carb rebuild kit
- zuk coil mod on front axle?? please help
- Diesel swap on a 92 pickup
- Pcv hose for the 22rte
- Good toyota websites for parts!
- Rebuild or just seals?
- Burning oil
- longfield or Dirty 30s
- Check engine light out if no where!
- 22re Sputtering....
- will 5in hd sas kit clear 38s
- 1985 22r Head Gasket Fiasco
- 5vzfe timing belt help
- PS pump
- 97 4rnr fan clutch 6 cyl.
- 1989 v6 pickup starting issue
- Transmission dipstick location
- Alternator belt tension
- 22re wont start.
- Source for rear bumper and receiver
- Factory 4.88 question
- Starter where can i buy? Not online
- What to look for with 92 4runner Hilux 2.4l diesel
- 92 rear bumper build
- 87 pickup. Need help Replacing a CV axle
- stubborn wheel stud
- 90 model 4Runner 3.0 won`t hold coolant temp
- 81 Yota "hopping" in 4x4 high
- Need help replacing 2004 v6 4runner air fuel sensor passenger side
- 3rd setup prices
- New toyota owner...Got a few problems.
- Changing Tranny Oil Help
- Modified my t-case...the wrong way. How bad did i screw up?
- 1986 Toyota Turbo SR 5 Irratic Miss
- engbldr or grumpys performance?
- Motor swap
- intake question
- Rear lockers? Need advice.
- new here, rough idle
- IFS third member fit in straight axle?
- 1996 T100 front drive axle replacement
- SAS axle candidate?
- Piece (basket?) missing from VSV, do i need it?
- check engine light flashes on acceleration
- Difference between 1989 and 1990 truck?
- Fuel pump location on 85&88 4wd 22RE
- What kind of cool motor swaps can i do in a 94 toyota pickup?
- 83 SFA remove front axles for HP third
- 79 toyota vacuum advance distributor 180 out
- Why does this circuit work?
- Por-15
- 95 4Runner knock sensor problems!!
- intermitent stalling
- Flopped my 4runner
- 90 4runner 3vze, coolant leak, identify part
- 3.0 flooding help
- 85 yota grinding gears in 2 but not 4?
- funny brakes
- Bj Spacers and Shocks
- Fix or Forget? 95 Truck Crash
- slack in acelerator cable
- High Steer; What is it? Do I need it?
- Thread pitch for an a340f drain plug
- fuel gauge problems
- Timing help
- Steering Rack ???
- 2003 Limited Runner Project
- HEI Coil and Distributer cap for 22RE
- Random hose
- keeping tranny fluid and transfer case fluids separate
- body work
- is there a way to mod the window sqiurter so the wipers dont come on?
- 1994 toyota pickup gas mileage
- Whats happened here?(Motor blew up internals)
- need advice
- Recommended brand of ball joints?
- Emergency Brake Cable - Is It Safe?
- 22re 1986 4runner rebuilt HELP!
- lift kits
- 90 3.0 4runner idle miss
- truck won't start - some diagnostics done...
- Fsm
- zuk mod question
- Lighting Dash mod- Pics
- 88 toyota speedometer gear teeth count?
- 85-88 interchangable
- Tire whistling...
- Header
- After 2" lift the front sits way higher than rear
