PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. finding local yotatechers
  2. torsion bars
  3. 98 taco ticking only when hot
  4. Knuckle arm help
  5. EFI to carb swap on 85 pickup
  6. 2005 V8 Tundra Heater Problem
  7. 95 4runner 3.0 poor gas mileage
  8. 5VZ-FE bucking, stumbling, misfire problem solved - spark plugs
  9. If You Are Running On 35 Inch Toyo MTs...on a 3rd gen truck
  10. 93 to 85 bumper swap
  11. 2009 Tocoma
  12. newbie help with loading pictures
  13. Lower Front End Submerged In Water
  14. Soft brake pedal
  15. 22r timing chain wear, pics
  16. Have I screwed up my Power Steering using PS fluid vs. ATF
  17. 94 pickup 22re overheated won't start
  18. Leaking oil
  19. Ball joints etc.
  20. Axle Identity Question...
  21. 87 22ret 4x4 SR5.. been sitting for 10+ years
  22. First Car?? (1986 Toyota 4Runner)
  23. Changing Transmission and T-case fluid, alot of controversy what to use
  24. 87 22RET 4x4 SR5 Needs the pros
  25. 1990 Runner Lift Cost
  26. Driveshaft orientation
  27. I might be dumb
  28. starting to tune my 22re
  29. what is this coolant system part? I need a new one.
  30. Burn exhaust valves with no exhaust? 5vz
  31. Newbie/ 2010 Tundra front end noise
  32. looking for a little advice...on a reliable small truck
  33. 92 toyota pickup clutch is slipping in 4th and 5th gear
  34. Possible to replace stock headlight bulb with hid 55w bulbs?
  35. 3rd gen fog light wiring connector-will universal plug fit
  36. 91 toyota p/u
  37. 87 4runner-replace new bushes with Prothane super kit
  38. Battery Size Question
  39. fuel tank
  40. Budget auxilary driving lights?
  41. Specifications of ngk spark plug wires: Te66 or 4412??
  42. What will help my horsepower on a 94' 4 Runner??
  43. 94 22re RPM output signal question
  44. 91 3.0 into a 94 3.0 4runner
  45. specifications of a Toyota Pickup pre 84
  46. 93 toy stalls when starting
  47. Help! What is this part???
  48. Rear driveshaft flange. 8" rear.
  49. Gas spurting out below to right of Intake
  50. Suspension suggestions: 94 Single cab 4x4
  51. Where is the ECU port on a 30-80LE
  52. 95 4runner
  53. OE parts source
  54. egr delete questions
  55. Swapping Diffs Quesiton
  56. 15" Steelies vs. 15" Alloy wheels - MPG/Power Questions
  57. 1985 toyota pickup
  58. fuel gauge always reads full 86 pickup
  59. balljiont spacers and susp lift
  60. Rattling Noise on start up and random RPMS
  61. Startup issues
  62. aftermarket tach
  63. Lockers
  64. Rusted metal flakes in transmission fluid
  65. Testing an SR5 oil sending unit...
  66. Bad NSS cause tranny not to shift properly?
  67. Power steering groan
  68. What front leaf springs are these??
  69. 185 toyota hilux surf 1994 model 4wd flushing
  70. 88 4runner Rear window bolt location
  71. 1990 4Runner Trailer wiring and shifter issues
  72. Rock Slider ideas and offroad tires
  73. Quick 22re question
  74. 88 4Runner Transmission Troubles
  75. 3rd member swap
  76. New (to me) Truck Owner!
  77. 94' 4 Runner MAP LIGHT REMOVAL?
  78. tundra motor swap 2002 motor into an 03 big problems
  79. a/c discharge line
  80. blow by?
  81. new memeber here!
  82. Help with 94' 4 runner splash shield question?
  83. Mystery Stall?
  84. Interior panel velour question
  85. Rear end bearing+locker help
  86. 08 Tundra Tail light assembly disconnect
  87. 1986 clutch plate replacement
  88. 86 pickup
  89. Manual transmission fluid advice
  90. Residue on radiator cap?
  91. 87 4Runner windshield washer button removal
  92. 86 pickup knocking
  93. 1988 pick up v6
  94. 86 runner hard to shift warm, easy when cold
  95. Gauge/ dash removal on 04 tacoma
  96. ball joint spacer height vs actual lift
  97. What are the weak spots on a 1989 4x4 Pickup?
  98. 86 pickup 22r backfire
  99. 8 lug axle
  100. Sporadic Knocking Sound - Power Not Affected
  101. power steering help
  102. Light behind speedo doesnt work!!
  103. new to toyotas
  104. 1980 L43 shifter removal
  105. 91 toyota p/u
  106. Speedometer gear problem in transfer case
  107. Hard to start when cold. Loss of power.
  108. 1991 4runner IFS
  109. 91 toyota p/u
  110. I need of a good frame straightening shop
  111. 22re overheating
  112. 3rd gen 4runner. Deckplate & Weird thing inside.
  113. 1993 22re burning oil during start up
  114. how to replace shifter seat 1980 toyota 4x4 4speed
  115. Blinking 4wd light on dash
  116. All Power windows not working.
  117. Speedy break bleeder
  118. 1991 Pick up
  119. Previa Problems
  120. Overheating issue after top end overhaul
  121. toyota t100 3.4 1997 "cylinder misfire"
  122. O/D Light Flashing with MANUAL Trans and Door Buzzer?
  123. Ball Joints
  124. Truck noob- 2013 TRD OFFROAD
  125. Electrical Problem?
  126. suzuki transfer case in yota?
  127. Gear/tire size help..
  128. '94 22RE intake pics (rear of intake)
  129. Thinking about trading the Runner for a Tundra
  130. OEM Toyota Parts Websites - Recommendation??
  131. knock sensor issues
  132. Noobie question for v6 5spd swap
  133. Bought a 1986 Pickup with a 22RE Turbo and need some advice.
  134. blowing tail light fuses - HELP - 97 4Runner V6
  135. 87 Runner lifting questions sag leafs
  136. Coolant in my exhast
  137. Regearing the front- what do I need
  138. HVAC diagram needed.
  139. Teach me to boost
  140. gangster lean in rear 93 22re
  141. my 4runner has a saggy A$$ (everything is new)
  142. Name that part...
  143. 33x12.50 gearing?
  144. Battery, alternator, or neither?
  145. Is there a diff lock on this axle?
  146. gear advice
  147. Head Gasket or ?
  148. What Transmission Fits
  149. transmission lines
  150. Truck wont run
  151. Parking brake question...
  152. Truck idling bad
  153. Lockers?
  154. 87 4runner 22re rough idle and running really rich
  155. Questions about Early 90's Pickups
  156. charcoal canister bypass
  157. Shocks...Easy or Not ?
  158. Rusted Axle Housing
  159. 2.7 3rz 4cycl. Over revving
  160. Coolant leak
  161. looking to buy a 3.4l 4runner
  162. starter question?
  163. truck want idle after it warms up?????
  164. elocker into 4th gen runner ?
  165. Headlight switch affects Cruise control-2004 Tacoma
  166. Timing Belt Change??
  167. Loose Wheel Bearing or Bad Ball Joints
  168. Brake line help
  169. 97 toyota lift decisions..
  170. 1986 Turbo issue
  171. Need help figuring this out.
  172. check engine light
  173. Backwards battery
  174. 85 bottom end 82 top end
  175. 1999 SR5 suspension sag fix for a newbie
  176. Napa Silver Filter - bad move?
  177. Newbie needs advice!
  178. Traction control problem
  179. Help/Ideas for a Newbie
  180. 3" Lift with Differential drop kit???
  181. Identifying a 1" bore master cylinder
  182. Any ideas on mods for an 84 Toyota truck owner
  183. Newbie with fuel issue.
  184. Possible bad air flow meter???
  185. Painting leaf springs.
  186. Oil Water mix, but not head gasket?
  187. 4x4, '83r VS '85re oil pans?
  188. Custom truck build
  189. 22re cuts out at 3000 RPM
  190. Firing problem???
  191. need help with an idle issuePleas!!!!
  192. Leaf Spring Top Plate/Pad (?)
  193. Battery bracket
  194. Zuk mod or just a repair?
  195. 89 pickup grill problems
  196. Fuel pump?
  197. Brake bleeder caps
  198. Heater issue
  199. putting valve seals in a 22re motor
  200. engine idle problem need some help please
  201. tune up and suspension help needed
  202. 83 PU 4X4 MT No Start Except On Compression
  203. Wife Takes 4Runer To Jiffy Lube - it freaks out
  204. Will the spider gears from an 8" 3rd member fit a 7 1/2" 3rd member
  205. My new 1990 4runner!
  206. engine & tranny swap auto to manual
  207. What does ASV valve do? '77 2wd 20r
  208. Wiring connector help!!!!!!!!!!!!!
  209. bucket seats in my bed
  210. so my muffler fell off
  211. Speedometer is off
  212. vacuum and hose routing
  213. how to remove shifter boot on 4speed 1980 4x4
  214. 8" Diff Question
  215. dying at stops, rough idle...please help
  216. Possible first Toyota purchase
  217. Horn help
  218. U Joint replacement Advice needed
  219. 1995 Toyota 4runner limited BLOWN HEAD GASKET
  220. Lurching in first and second gear
  221. Park brake cable inside drum is missing
  222. 2nd gen pu half door ?
  223. running w/o a thermostat
  224. Rear Seats locked in down postion, 1st gen
  225. Rough Idle w/ AC running - 94 PU, 22RE
  226. No fluid to front breaks
  227. need some help here
  228. Rough Idle - Running Rich when Hot???
  229. Engine or Axle First?
  230. 88 yota pickup question
  231. loose switch in glove box. Do you know what for?
  232. 85-89 4runner newb interior questions...
  233. Door jam/ dome switch & deck lamp switch
  234. Locker will not lock
  235. Diagnostic code 32-air flow meter signal???
  236. Overdrive Light
  237. 97 tacoma 2wd vehicle speed sensor
  238. 3.0 swapped out - New issues with cold start and operating temp
  239. 91 toyota pickup want rund righ need help please!
  240. Need clutch and transmission help on a 86 pickup with a 22r
  241. Can i shorten my bump stops
  242. increasing tranny whine, aluminum shavings
  243. curious question
  244. manual steering - 94 Toyota Pick up
  245. OEM wheel question
  246. 1st Gen 4runner owners - Aftermarket tires/ wheels???
  247. 89 Toyota 3rd swap
  248. 88 22re missing at idle
  249. 1986 Toyota Pickup Need Info.
  250. Sway bar links - 87 4Runner, 4WD, 22RE
