Sponsored by: CARiD
Backwards battery
Old Oct 2, 2013 | 04:52 PM
1371engineer's Avatar
Backwards battery
So I accidentally hooked up my battery backwards. It was a new battery as well. Checked all the fuses and are all good. Nothing happens except the seat belt indicator comes on when I try to start it. What else could be the problem?
Old Oct 2, 2013 | 04:55 PM
Green93's Avatar
Have you checked the fuses under the hood? There are also fusible links in the wiring harness to protect against things like that. I'm not exactly sure where they are located but the FSM should point them out.
Old Oct 2, 2013 | 05:01 PM
rworegon's Avatar
This thread may help. While it's from a jumpstart error in the thread I linked, your issue is similar.
Old Oct 2, 2013 | 05:19 PM
Yup checked fuses under the good as well
Old Oct 4, 2013 | 02:44 PM
rworegon's Avatar
What solved the power issue?
Old Oct 4, 2013 | 03:53 PM
Ended up being a fuse. Didn't clean them off so I could see clearly. Wiped them down and looked again and seen the break. It wa the 120a fuse
smilen724
13
Nov 8, 2015 04:11 PM
Chicken12
Oct 14, 2015 03:54 PM
Gone Fission
Oct 7, 2015 12:42 PM
mreagen
Oct 5, 2015 04:27 PM
shredder4286
Oct 1, 2015 01:09 PM
