Sponsored by: CARiD
egr delete questions
Old Nov 21, 2013 | 06:26 AM
twoyotas86's Avatar
I ordered the delete plates from lcengineering. i just want to know how many vacum lines i will loose. and what all parts i will take off. Im doing this to an 86 22r. Ive searched but havent really found my answers.
Old Nov 21, 2013 | 06:57 AM
Terrys87's Avatar
On a 22r, it is alot more complicated. There is a thread on here somewhere about it and will see if I can find it. I was going to try it on a 22r and wound up being more then I wanted to tie into. If you want to remove alot of the things, I would suggest going with a Webber carburator to get it done correctly.
Old Nov 21, 2013 | 07:10 AM
twoyotas86's Avatar
thanks. I've been searching I've found a lot of ppl that did it to a 22re but not a 22r.
Old Nov 21, 2013 | 07:47 AM
kawazx636's Avatar
You can get rid of all the vacuum lines except for the vacuum advance to the distributor. All smog equipment can go too. I personally convinced LCE to make a full desmog kit - it is now available on their website.
There is plenty of information on desmogging a 22R, you've just been searching the wrong forum section - you need to troll around in the Pre 84 section. I made a desmogging thread for the 22R. Check it out here:
https://www.yotatech.com/forums/f114...torial-264405/
Let me know if you have any problems or questions
Old Nov 21, 2013 | 08:51 AM
twoyotas86's Avatar
Thanks! Very good writeup! I'm not looking to Get that in depth with it. For now I just Need to delete the egr so I can run my header. it didn't come with the egr hookup. And my factory manifold is shot. I will be switching to a weber and desmoging in the future.
Old Nov 21, 2013 | 10:17 AM
kawazx636's Avatar
Well, just to let you know, it takes no time to do. If somebody dropped their truck off at my house with all the block off plates, hardware and about 4 ft of new vacuum hose, I could have it done in less than 2 hours. Literally, the hardest part is getting up the courage to just start yanking every vacuum hose and everything that they are attached to.
Old Nov 21, 2013 | 11:10 AM
twoyotas86's Avatar
Can it only be done with a weber?
Old Nov 21, 2013 | 08:19 PM
kawazx636's Avatar
Nah, it can be done with the factory Aisin carb, but the results are better with a weber.
Old Nov 21, 2013 | 08:55 PM
twoyotas86's Avatar
Then its definitely on my to do list. With the 2 egr delete plates I got from lc will I be able to delete the egr and run a header? Sorry for all the questions I've just never messed with the egr on these engines.
Old Nov 21, 2013 | 09:00 PM
kawazx636's Avatar
There should be 3 plates: two for the air injection ports on the exhaust manifold and one for the EGR on the rear of the head on the intake side. There are several other plates need to do a full desmog. What header are you planning on getting?
Old Nov 22, 2013 | 08:14 AM
thefishguy77's Avatar
All I did to my 93 22re is.. Unhook the pipe that runs around the back of the head from the pipe that hooks in to the exhaust manifold. I out a plate on that sealed it up good with a new gasket and some rtv for good measure. Then I put my header on. I wanted to leave everything there since its not a big stretch for my state of Wa. To go completely commie like Cali. And require a visual as well. That way at least I have the parts in good working order to hook it back up. BTY the header I hooked up was a NWOR tri y. Old header that I bought for my 85 but never had the chance to install. Really nice thick flange. I did loose some low end torque at the very bottom but I am 2 1/4 a the way back and an 83 afm for the air intake. I am in the middle of a head gasket at the moment but there are some pics in my build thread. Should be easy enough to find.
Old Dec 5, 2013 | 09:38 PM
twoyotas86's Avatar
Thanks for the help guys. I ve been really busy working on my other truck (cammed 05 silverado 5.3) trying to get it back together. I did find an engine. A bored .30 over 22re im going to convert to a 22r. Also the header im using is a pacesetter. I know its a sucky header but I got it new for 20 off craigslist.
Iceman4193
Aug 28, 2015 08:43 PM
e_richard
Jul 30, 2015 06:50 PM
Dakotaneu
Jul 27, 2015 12:03 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
