Sponsored by: CARiD
Parking brake question...
Old Oct 11, 2013 | 09:19 PM
JFW's Avatar
JFW
So not having seen another 1st gen 4runner's parking brake before, I had no idea why my parking brake light is always on. lol Now I realize that the tab that pushes the button on the switch when it's in is gone. It was like that when I bought it. All I see on the end of the lever shaft is a ring of plastic that looks like something might've broken off of it. Anyone know if that tab or whatever can be sourced or replaced? Anyone want to chime in with their fixes? I saw a parking brake for sale on eBay, but it looked like the tab was a metal piece that inserted into a hole. Maybe that was something done after the stock one broke? Any help is appreciated, of course. Thanks!
Old Oct 11, 2013 | 09:39 PM
rokblok's Avatar
That brake light can also be on if you're low on brake fluid.
Old Oct 11, 2013 | 09:42 PM
JFW's Avatar
JFW
Yeah, I saw that on another thread when was searching for possible reasons why the light was always on. The brakes were just redone a few weeks ago and the fluid is good. Thanks though. Plus, the light goes off when I push the button on the switch in with my finger. lol
Old Oct 11, 2013 | 09:51 PM
aztoyman's Avatar
If you can't find another one you could easily rig something on it to push the switch.
If it has a hole for a pin maybe all you need to do is go to the hardware store and find a roll pin to stick in the hole.
You could probably take a small piece of angle and hose clamp it on the shaft so it pushes the switch.
It's a pretty simple setup. You could probably McGyver it somehow.
Old Oct 11, 2013 | 10:52 PM
JFW's Avatar
JFW
Yeah, that's what I'm thinking. I might just drill a hole and jb weld or loctite a pin in there.
Old Oct 12, 2013 | 12:57 AM
wyoming9's Avatar
Red face
There should be a hole already there.
The one you saw is the correct set up a pin is pressed through the shaft maybe yours fell out or broke off.
Old Oct 12, 2013 | 07:54 AM
JFW's Avatar
JFW
Really? Well damn....OK. I'll look again. Maybe the shaft spun to where I can't see where the hole is. Thanks Wyoming9!
jashoeuh
Nov 18, 2024 08:08 AM
skoob
Oct 15, 2015 03:23 PM
romex1
Aug 10, 2015 06:21 PM
terminator
Jul 27, 2015 07:13 PM
CanRunner
Jul 20, 2015 01:29 PM
