Sponsored by: CARiD
curious question
Old Sep 10, 2013 | 01:30 PM
87blyota's Avatar
curious question
howdy all i just picked up a 87 toyota truck 4x4 5speed the other day it starts up great and everything except for after you drive it for a while. if you turn it off and try to start it itll take a couple tries or if you give it some gas itll fire up. just wondering what causes may be if the carb just needs tuning or what this is my first toyota and it does have a 22r engine.
Old Sep 12, 2013 | 03:09 PM
87blyota's Avatar
anyone?
Old Sep 12, 2013 | 06:12 PM
rokblok's Avatar
Pumping the accelerator pedal once or twice is normal on carbureted vehicles. Since the fuel is sucked into the combustion chamber, once the engine is stopped the fuel will mostly evaporate. It takes a couple pumps to put fuel back into the intake passages, via the accelerator pump. If its taking several/constant pumps, check your float level to ensure there is fuel in the float bowl. If not, work backwards. Float level adjustment, fuel pump, hoses, filter, etc. If there is fuel in the bowl, a new accelerator pump may be necessary, which usually comes in a carb kit.
Whew....
Old Sep 12, 2013 | 07:02 PM
87blyota's Avatar
thanks man pumped it 3 times after i got off work and bam fired right up :p
Old Sep 12, 2013 | 07:19 PM
Kiroshu's Avatar
^-- Sounds good to me ^_^
82yodahickman
34
May 16, 2017 01:00 PM
montanatruck
Feb 26, 2017 07:07 AM
kirkrunner
Jul 27, 2015 07:59 PM
Logz808
Jul 26, 2015 07:09 AM
