Sponsored by: CARiD
Newbie with fuel issue.
Old Sep 29, 2013 | 08:32 PM
88yotatoy's Avatar
Hi guys, Im mike and i own a 1988 pickup 4x4 5spd. I have only owned it for a month or so and it has yet to get me to work and back. Check engine light came on and it started acting like it was running out of fuel. I changed the main relay, computer, and straight wired the pump. and still can find the problem. Im getting fire to the plugs and distributor. Pump is running i know that for sure i can hear it when i connect it to the battery. I took an injector connector off and it is getting power. Im lost and have no other idea's as to what could be wrong. Any ideas or info would be great.
Mike
Old Sep 29, 2013 | 09:12 PM
thefishguy77's Avatar
Fuel filter been changed?
Old Sep 29, 2013 | 09:15 PM
88yotatoy's Avatar
No but i am getting plenty of pressure at the cold start injector.
Old Sep 29, 2013 | 11:43 PM
wyoming9's Avatar
Red face
well just what caused the CEL to come on?/
The code might give you an idea what to look at.
You replaced the ecu with a brand new one??
Could be as simple as wires and plugs
Old Oct 26, 2013 | 09:19 PM
slow-mo's Avatar
So this is a new issue? It was running fine before?
The sound of the fuel pump operating is not a correct way to test fuel pressure. You need to test for fuel pressure.
Since you have spark at the spark plugs, the engine still needs fuel, compression and timing to operate.
Old Oct 28, 2013 | 12:51 AM
Terrys87's Avatar
Which motor you have? 88 had two options. The very least I would change the filter as it is probably needed anyways. If the pump was working before, not sure why you bypassed it.
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
RaginAsian91
All Other Toyota Swaps
Aug 23, 2015 10:27 AM
raptor510
Aug 19, 2015 02:15 PM
maddogd
Aug 9, 2015 04:32 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
