View Full Version : Newbie Tech Section
- Oil Question/Suggestions
- Diagnostics Trouble Code P0420
- 96 tacoma 4wd mpg decrease what to look for
- Alcan Vs. All Pro
- Temp Gauge
- 1991 Toyota Pickup rearend
- When 4WD engaged front end makes noise
- Starting question, MAF, troubleshooting, HELP!
- What to do with two 2nd Gen 4runners?
- Wheel Bearing preload and fsm
- new struts/shocks?
- O2 sensors
- Exhaust question
- belt/pulley tensioner bolt question
- Brake change advice where to buy OEM?
- 22RE Oil Filter Removal
- Starter problems?
- What breaks??
- headgasket/timing chain-need some advice
- Too much slack in locked rear
- Seafoaming a 3vze?
- dumb electrical question
- 86 toyota 4x4 pickup , 22r engine, carberatedd
- L50 / L52 Input Bearing/seal.
- 87 4runner needs new engine any recommendations
- Need help with sluggish running 22rte
- How to install new studs on Struts?
- Idler Pulley Squeak?
- fuel or timing or egr or???
- 90 body on 07 Chassis
- All New to me!!!! Trying to get all the help I can get! Thanks
- Interference issues with 22R
- what leafs am i looking for???
- Tire decisions
- 88 to 94 3.0 engine swap
- New Owner in Aruba: Very Stiff Suspension, need suggestions, lots of questions
- Supra AFM P/N 74-20028
- m8000 portable winch anchor
- TG Or all pro offroad IFS elimator
- Hummingwhen idling from around motor when warmed up.
- Spark plug correct gap size 22re???
- Noob Oil Pan/Valve
- Putting new oil filter on?
- truck wont start even with new battery and no sound/noise of any sort
- need 88 pickup auto 4wd ATF recommendations
- Switch ideas?
- 3.0 to 350 chevy
- Parts I should rob off an '85 Celica 22RE??
- Tire size / Gear help
- Ball joint
- Radiator replacement for a '90 Pickup?
- Fault Code 12
- transmission help
- Fan and Fan Shroud
- 07 FJ Transfer Case--what type fluid?
- 06 taco spark plug change
- 92 toyota wont stay in 4wheel drive
- Need info on 22r engine in a 85
- ECU Pinout
- What to keep and what not to keep?
- Gas tank skid plate?
- transfer case tech question?
- Hard to shift T-100 when cold
- Mixing gear oil weights
- New rear springs - alignment?
- Driver side Transfer case on W59 Trans Info Needed
- WTD b/t spacers and increased backspacing?
- 1991 yota 4x4 problem no power from 4wd
- 2010 FJ Cruiser Cold Air Intake
- Won't Start
- 1988 3vze oil question
- Newbie 3.0 to 3.4 Conversion questions
- How much ATF for 99 4R 3.4 auto
- Oil Leak take a look.
- Oil Question:Valvoline MaxLife
- slave/master leak
- 22RE Motor Rebuild HELP?
- imported engine dealer???
- I need Advice on gears
- 94 4Runner has a seized engine
- Brake removal
- Hesitation above 50mph and front end viberation
- Weird Throttle Issue
- 2011 Tacoma and TRD package?
- e-brake cable
- Front Drive Shaft Angle Question
- Input on OBDII scan tool - no laptop
- installing electric fan need help with wiring
- lowering a fabtech 6in lift
- 93 pickup hvac backlight question
- lift size????
- 85 22r getting ready to lift
- rear springs
- Diff plugs stripped
- Stock 2006 Tacoma 4x4 2.7 litre
- difference between an ADD front diff and manual lockout diff: 97 Tacoma
- 3.0 V6 O2 sensor wires
- Steering wheel shakes around 45mph
- Spring on throttle body
- U joint question
- water pump just installed but its still overheats.....
- 99 4Runner lift options
- Is this the dreaded strawberry milkshake?
- 1999 TACOMA w poor mpg
- 94 SR5 4Runner died.... repair or move on....
- Feels like I only have 1 cylinder!!
- White exhaust smoke from 1987 4Runner
- 84 p/u dash clock
- coilovers on 6 inch lift
- 22re no spark
- New headlights
- 22RE Exhaust considerations,...
- Spacer/adapter questions
- 22RE horrible nocking noise truck died no power
- removing crank pulley
- weber problems please help
- oem graphics for 1995 tacoma xcag 4wd lx
- 87 4runner turbo swap
- 2nd gen 4Runner/SURF front Diff Swap Questions?
- Need sending unit for gas tank
- 1992 toyota pickup aint ran in 1 yr
- 2wd 2.4 22re waterpump replacement help!!
- upper and lower control arm bushings
- Need a bed mat for my '85
- 4runner rear coils on my 86 Pickup????
- Adjusting clutch rod throw
- warn 8274 opinions i have 2.
- sink money into a ifs eliminator or sell out and get a sfa rig?
- 96 4runner, bout to pull the trigger on new rims/tires.
- chopin up 3rd gen 4runner
- 46K km Hilux with strange fluid leaking inside and overheat
- fuel doctor
- what gaskets to replace after serious over heating
- Rear Leaf Spring replacement
- L50 5 speed tranny question
- OEM Brush Guard - Same Between 92-95 4Runner and 92-95 Pickup?
- Fender Flares
- 1993 GMC Sierra K1500 4x4-Freeze Plug
- weber
- Am I overgeared??
- u joints?
- Timing belt, water pump, what else?
- Newbie Question - Slight Squeal
- 285's on 3rd gen wheels, '92 4runner?
- Acting like it is flooded
- fuel filter orientation?
- 3VZ Alternator Upgrades?
- INTEGRATION RELAY output for Dome Lamp? Any good suggestions?
- What brand of brake fluid do you use for your gen 3 4unners?
- 3.0
- 03 toyota taco.....cel won't go off!!!
- bumper/hitch receiver
- Marlin Crawler, TG, ALL Pro, Addicted Offroad bumpers
- Pricing for installation?
- Which Marlin Clutch?
- Solid axle swap newbie questions
- check engine light
- will a 22re 2wd harness & ecu run a 4x4????
- How to identify LSD?
- Newbie with questions
- Bare Minimum Tools for 4x4ing?
- Charging issue
- repair question 22re
- Which grill looks better on the pickup?
- 84'4-runner axles?
- steering linkage from yota to 1ton
- 89' 4runner Body Lift Question...can't seem to find the thread
- welded gears
- im putting together a long block 22r
- TRD E-Locker retrofit questions...PLEASE HELP!!
- Rebuilding an engine
- Hi-Lift mounting
- Long Travel Suspension IFS Tips and Helpful Hints
- Spongy brakes
- Im thinking about switching my 89 cab on my 1989 toyota 4x4 reg cab to the 96+ cab
- Take motor out?
- How do i get more horsepower?
- Comparing two Timing belt/Water pump kits
- 86-90's suspension
- need help add front diff
- KC lights wiring question
- 75k on a rebuilt 22re engine
- 4runner transmission wont stay in reverse
- 87 22R Which cam???
- 03' Toy Taco..CEL on. Low Eff. Bank 1
- help with P0171 and P0174
- Transmission doing nothing
- 3rd gen cup holder/console swap
- new to the 22re with a timing chain question
- Cold Weather Idle
- which generation is best?
- 22r 84 vs 85
- where do you get gauge bulbs?
- Engine/model question
- Bellhousing question
- Toyota Project
- Changing leaf springs?
- 86 4cyl. axle housing accepts 92 third member?
- harness and ecu questions
- 22re AFM work for 22RTE?
- gauge swap
- Building a bumper for my 1st gen runner Need some ideas
- E Brake Light
- 86 TOYOTA cranking, but not starting
- 98 3.4l Tacoma fuel pump
- 94 toyota pickup radio bezel
- poor gas milage
- Help! Trying to fix horn. Steering wheel is off. Easy fix isn't so easy.
- 3 in Trail Gear lift
- straight piping my 99 tacoma
- Safety belt lower position ?
- 84 pickup gas tank removal help needed
- plow frame mounting?
- auto trans swap
- Breaking the lock on my cam bolt
- white gunk in alternator connection?
- 1986 toyota wont start no electricity
- 06 Taco differential gear lube?
- Heat exchanger
- leaky power steering box
- 3rd Gen truck: No compression-coolant everywhere
- What is the best year of pickup, Newbe needs advise
- Picking up a '84 Extended Cab Tomorrow, weatherstriping, lift questions
- If you were to do it all over again, what would you do?
- building a 2" body lift
- Regular Fluids
- Need a little Information - 94 4wd -
- Trail gear spring hangers, will they work with 63's?
- Double Check-what are these in the pics?
- 1988 toyota 4x4 v6
- Can you remove oil pan on 3VZE with motor in 4Runner?
- new alt still not charging
- help with 87 yota project plans
- driveline length
- ifs differential more than 1 inch drop?
- 22re to a 22r? Would it work?
- 1995 4runner engine replacement -Newb in need of assistance!
- 86 to 81 driveline help
- replacing rotors 94 pick up
- ? Xtracab swap compatability
- Starting problem help!
- 2005 4runner lift/tires
- 3.0 engine removal problem
- crossover steering questions?
- 81 Toyota 22R, loud noise from Rear of engine or Transmission?
- LIft a 2WD for off roading?
- Dies while warming up
- Longer leaf springs?
- lifting my toyota
- What is involved in swapping to a V6?
