Sponsored by: CARiD
2wd 2.4 22re waterpump replacement help!!
Old Dec 22, 2010 | 11:10 AM
sq2124's Avatar
If you have any advice, tips, knowledge or fascinating wisdom that can help a young man like me please let me know. im trying to replace my water pump and so far ive taken the fan shroud out....aaand thats about it. what to do nextt...i'd like to do it on my own without a mechanic, mechanic will be my last resort. (tryin to save money, hope you can understand.) anyways if you have any pointers it is MUCH appreciated. THANK YOU AND HAPPY HOLIDAYS!!
Old Dec 22, 2010 | 11:28 AM
myyota's Avatar
If you already have the shroud out, next unbolt the fan from the radiator and remove it. Now unbolt the water pump and keep track of the bolts, some are longer than other. Once unbolted remove the old water pump, clean the old gasket off the timing cover and install the new water pump.
Old Dec 22, 2010 | 11:45 AM
sq2124's Avatar
Thanks man! those bolts are no joke to screw off.haha. i'll keep ya updated once i finish that. again thank you so much. Im pretty new at this. lol
Old Dec 22, 2010 | 11:46 AM
toyota4x4907's Avatar
Take the belts off next. Drain the anti-freeze. Removing the radiator isnt necessary, but it helps lots. You already have the fluid drained, so it only 4 bolts and 2 hoses. Beware, the lower hose is probably rusted onto both the radiator and the metal piping! Then remove the fan (4 bolts). Now, take a piece of cardboard, as you are taking the bolts on the water pump out, put them in the cardboard (like through holes) in the orientation that they are on the water pump. Like the top one, put towards the top of the cardboard.
Old Dec 22, 2010 | 12:02 PM
RBX's Avatar
RBX
^^^ Great suggestion as the bolts are different lengths.
I would add that i use a pry bar wedged againt the fan nuts while i break the others loose.
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
