Sponsored by: CARiD
weber
Old Dec 18, 2010 | 07:47 PM
elk4's Avatar
weber
ok here is he deal yes i search and search i just picked up a weber and wen i got it the dude said that it was bolt on it does not have a adapter plate or do some just bolt right up i have talk to a few people and 2 of them said it should and one said try it and see what happens do i need to bye anything to put this on my truck my truck has a 22r in it and is all stock and a pic of a weber all put on would help out a bunch thanks
Old Dec 18, 2010 | 08:05 PM
elk4's Avatar
ok ive been looking and looking and i think its a 34/34 its defiantly not a 32/36 the fuel port is straight across and not at a angle at all, and no both sides do not open at the same time so that rules out the 38/38
Old Dec 18, 2010 | 08:14 PM
streetlancer's Avatar
I believe you still need an adapter plate but not entirely sure...I'm sure someone will chime in...
Old Dec 21, 2010 | 02:57 PM
elk4's Avatar
i tryed it and yes i need one ooo well and i was talking to the dude i bought it frome and he tells me its a 38 can anyone tell me how to tell what it is or ware to find it stamped on it someware
Old Dec 21, 2010 | 03:04 PM
post some pictures, that will help
But, i think they are stamped somewhere on the base plate
Old Dec 21, 2010 | 03:22 PM
xxxtreme22r's Avatar
maybe putting a photo up will help. And yes you will need an adapter plate. If you can try to stay away from the two piece adapters.
Here is the webers 32/36 - 34/34 - 38 in that order top to bottom. Notice the 32/36 and 38 look similar on the top (square air horns where the 34/34 is oval.) The 38 will have syncro gears on the same side of the throttle cable connection. Thw fuel inlets on the 32/36 will look like a "Y" or "V" where the 34/34 will be a "T".
Old Dec 21, 2010 | 07:57 PM
elk4's Avatar
defiantly the middle one it has a t for the fule and the wired throdle cable hook up thanks its defiantly the 34/34 thanks i will still post pics
ok one thing tho mine has 2 deferent size holes i guess is what you would say for the secondary and primary if it was a 34/34 would they be the same size
Old Dec 22, 2010 | 09:22 AM
elk4's Avatar
i think i did this right
Old Dec 22, 2010 | 09:24 AM
elk4's Avatar
okm i had one more but it didnt work ovel with squareish horns and 1 butterfly
Old Dec 22, 2010 | 09:53 AM
herpestes's Avatar
http://www.lceperformance.com/Spiral...-p/1033028.htm
Old Dec 22, 2010 | 10:35 AM
elk4's Avatar
well they are a little cheaper threw summit
Old Dec 22, 2010 | 02:15 PM
herpestes's Avatar
no problem.........good luck on the install
Pri$erulz
Nov 17, 2019 08:03 PM
user 82300
Jan 19, 2016 02:01 PM
highonpottery
Nov 22, 2015 03:57 PM
kawazx636
Sep 29, 2015 08:22 AM
