Sponsored by: CARiD
Regular Fluids
Old Dec 3, 2010 | 08:46 AM
Cptchunky's Avatar
Regular Fluids
I did some searching and found only one answer to my question. I am changing some fluids in my 1988 3vze and I need to know what to use. Motor oil? What weight and how many quarts? Brake fluid? What DOT? Power steering? I found this out but will this work? http://www.autozone.com/autozone/acc...questid=310251
Old Dec 3, 2010 | 12:22 PM
MudHippy's Avatar
Motor oil: 10W-30 or 5W-30(cold spec) See FSM page EG2-13 for fill capacities
http://personal.utulsa.edu/~nathan-b...e/64tuneup.pdf
Brake fluid: DOT 3 or DOT 4(DOT 4 is back compatible/can be mixed with DOT 3)
Power steering fluid: Dexron II,III,VI
http://personal.utulsa.edu/~nathan-b...21lubrican.pdf
Features & Benefits
Maxlife dex/merc atf contains a blend of superior base oils and a unique additive package to help extend the life of transmissions with over 75,000 miles. Maxlife dex/merc is formulated to fight the 4 major caues of transmission breakdown including leaks, slippage, shudder and gear wear.
Seal conditioners help reduce leaks
Synthetic base oils better resist cluthc plate glazing and slippage
Advanced anti-wear technology to better prevent wear
Recommended for use where Dexron, Dexron II, III and VI; MerconŽ, MerconŽ SP and LV; Toyota/Lexus Type T, T-II, T-IV, WS; Nissan Matic-D, Matic-J and Matic-K; Honda Z-1 (except CVT); mercedes nag-1; mitsubishi diamond SP-II and SP-III; and many others
Good to go!
ladybugRC
458
Aug 21, 2020 10:41 AM
zanzabar0
Oct 11, 2015 02:56 AM
bradahman
Oct 1, 2015 09:24 AM
gentry
Sep 28, 2015 06:16 AM
