Sponsored by: CARiD
New rear springs - alignment?
Old Jan 1, 2011 | 01:32 PM
SDHNTR's Avatar
Just finished installing JC Whitney rear leaf springs. Fit well and pretty easy job with some help. My question now is... Do I need to go get the truck aligned?
Old Jan 1, 2011 | 03:31 PM
peow130's Avatar
uhhhh...
you shouldnt need to get an alignment.
Old Jan 1, 2011 | 03:39 PM
iamsuperbleeder's Avatar
yeah you can't align the rear anyway
the only time you NEED to get an alignment is after replacing steering components or major front suspension components like tie rod ends, idler arm, pitman arm, control arm bushings, ball joints, etc
aliments are not needed if any rear end work is done, or even front wheel bearing work
it is however a good idea to have it checked when buying new tires for instance
Old Jan 1, 2011 | 04:09 PM
SDHNTR's Avatar
OK, I guess I must sound really dumb. I realize you cannot align the rear. My question is, when they align the front don't they line the tires up with the rear? I've watched them do it and they seems to attach gizmos to the rears and line it up with similar gizmos on the front tires. So that is why I asked. If alignment means (at least partially) aligning the front and rear tires in a straight line, and I moved the rears, do I need to realign?
Old Jan 1, 2011 | 04:21 PM
874runnersr5's Avatar
nope, your leafs should have had center pins that go into the spring perches. I dont fully understand how alignment machines work but i think it uses the rear as a reference for the front?
Old Jan 1, 2011 | 04:27 PM
SDHNTR's Avatar
Yeah they do have the pins, they just dont seem very precise.
Exactly, that is what I thought too. So if they use the rears for reference, and you move them around, do you need to realign the front.
I feel like a total rookie with the questions I am asking today. Take it easy on me ;-)
Old Jan 1, 2011 | 04:35 PM
now that i dont know, i know you shouldnt have too.. like unless your rear end was so out it was dog trailing and then got a alignment to help it then added these new leafs thus making it out again.. but i highly doubt thats your situation. So you should be fine..
Old Jan 1, 2011 | 05:07 PM
SDHNTR's Avatar
I think I'm just gonna drive it. Unless I notice some pull, or uneven tire wear.
Old Jan 1, 2011 | 05:15 PM
VANCE164's Avatar
The rear on most vehicles dont need to be aligned but their are some that do just to let you know like most honda cars need a 4 point alignment and what not. now most of the time only front ends need thrust angle alignments to kep the tires from wearing unevenly.
Old Jan 1, 2011 | 05:58 PM
peow130's Avatar
Well, if you noticed your rear wheels are angled...
Then yeah, you should probably fix that..
Old Jan 2, 2011 | 01:53 AM
muddpigg's Avatar
Caster and camber are fixed, can't adjust them on IFS and is going to take cutting and welding for caster on SA, camber is fixed.
I need to get my rig aligned. On my list of things to do.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
yourrealdad
Jul 21, 2015 11:13 AM
hangtown88toy
Jul 10, 2015 02:33 PM
Nickdigg
Jul 7, 2015 06:04 AM
