Sponsored by: CARiD
white gunk in alternator connection?
Old Dec 5, 2010 | 09:17 AM
fishingorwishing's Avatar
Like the consistency of clay. On both the male and the female side. Is it di electric grease? is it normal? I was having funky symptoms that possibly made me think it was alt.? will try and get a pic on here tonight.
Old Dec 5, 2010 | 09:48 AM
aquaprice's Avatar
Sounds like dielectric grease
Old Dec 5, 2010 | 10:36 AM
Ya it is di electric grease should I clean it out and reapply? and how so? will baking soda and water work or should I use some sort of electric cleaner? Maybe MAF cleaner? should all connections have di electric? alt., ps pump, starter, AC unit? I have had my motor rebuilt and putting it back in Truck has 244,000 miles on it
Old Dec 5, 2010 | 11:14 AM
rworegon's Avatar
MAF cleaner should be fine or something like CRC Electronic Parts Cleaner. I tend to put a light smear on the female side of all connectors so when it pushes over the male metal slot it leaves a bit where the connectors mate. On the alternator, I use a light coat over the nut on the connection to keep moisture out. Also, a light coat up in the boots of the spark plug cables. Others may have differing opinions, but these methods have worked well for me.
Old Dec 5, 2010 | 11:15 AM
Rerunn's Avatar
I would try clening it out with electrical contact cleaner but DONT soak it down you should be able to spray it and it should practically melt off per say but i would put it in any connection exposed to the elements itll DEFINATLY help keep out corrosion buld up between your contacts
80Truck
Oct 12, 2025 07:25 PM
JaredL
Mar 28, 2016 09:08 PM
old87yota
Sep 9, 2015 12:39 PM
corey519
Aug 12, 2015 11:12 AM
