Sponsored by: CARiD
Starting problem help!
Old Nov 30, 2010 | 08:54 PM
mitchell_0553955's Avatar
I was driving my 93' 4runner last week and it completely shut off on me. I got out and pushed, luckely I was 3 houses from my girlfriends. So I put it in park and I wasn't getting any power. Had to undo transmission linkage to put it in neutral to move it. I cut back the cable running from the postive battery terminal to the fuse box and put on a new eye hole. Started up just fine.
Went back the next day to move it, so I put the linkage back together, and with full power to all accesories and lights, it wouldn't start. All I got was a clicking sound.
I got a brand new battery, got that checked, new starter, new starter relay, new ALT fuse, and new battery terminals. Still no start, still the click. I tested my pos. connection at starter and I was getting full voltage. ANY SUGGESTIONS?
Old Nov 30, 2010 | 11:44 PM
wyoming9's Avatar
Red face
Just a guess but you never said what if anything you did to your ground cables. I say bad ground connection.
What kind of new battery terminals did you put on??
just curious you didn`t disconnect or have a poor connection on the wire that pulls in the starter solenoid coil.
Old Dec 1, 2010 | 01:37 PM
The ground from the battery to the fender well? I replaced that about a year ago. It looks fine.
I just put standard terminals on. Nothing fancy.
Which fuse is that comming from? and how would you replace that wire?
Old Dec 1, 2010 | 09:09 PM
Fixed it today! Woohoo!
Old Dec 1, 2010 | 10:02 PM
wyoming9's Avatar
Red face
Be nice to know just what you fixed????
Old Dec 2, 2010 | 11:54 AM
When I undid the linkage I must not of put it back together right. I undid it again put it in neutral and it started right up.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
