Sponsored by: CARiD
Front Drive Shaft Angle Question
Old Dec 28, 2010 | 09:36 AM
monst's Avatar
Arrow Front Drive Shaft Angle Question
I have a 1995 4runner, The lift on my truck causes the front drive shaft angle to be a bit extreme. It cause a slight vibration. I was wonder if the older model Toyota trucks 80s drive shafts support higher angles like ive heard. If so could i correct this issue with a drive shaft from a late model toyota? any info is appreciated.
Old Dec 28, 2010 | 09:40 AM
waskillywabbit's Avatar
With only a 3" lift I doubt the angle is that extreme. Probably worn ujoints or slip spline is more likely to blame.
:wabbit2:
Old Dec 28, 2010 | 09:43 AM
monst's Avatar
It is actually closer to 4-5 lift.
Old Dec 28, 2010 | 09:46 AM
monst's Avatar
update signature.
Old Dec 28, 2010 | 09:50 AM
So which is closer to 4" of lift, 3" or 5"? 4-5" of true suspension lift doesn't happen on IFS.
4x4wire has a write up about clearancing IFS ujoints. If you've got that much lift you need more driveshaft spline length too.
:wabbit2:
Old Dec 28, 2010 | 09:52 AM
dropzone's Avatar
Fossilized
inspect your DS CV and U joint, grease it.
if that is not your issue.
clearance the CV for more clearance:
http://www.4x4wire.com/toyota/tech/cvmod/
monst's Avatar
It is actually a bracket lift. =\ sorry for the confusion.
aa1911's Avatar
Any pics? I really just want to oogle more photos of that clean lookin' runner you got...
I think my front driveshaft on my 93 runner is about to go; I pumped grease into the U-joint and it all came right out the other side in a gob.... no bueno... it's OK though, SAS and complete suspension/driveline overhaul soon...
speaking of which, Wabbit, you're going to get tons of my money this summer....
Old Dec 28, 2010 | 09:56 AM
Ooh money. Shiny
:wabbit2:
Old Dec 28, 2010 | 09:58 AM
monst's Avatar
I am positive its the angle, that mod will probably do the trick. the truck is in the process of the 3.4 swap and some rear coil spacers. I was hoping the older front drive shaft would be able to fix it also.
http://dl.dropbox.com/u/12912/485430...844b1c0f_b.jpg
Old Dec 28, 2010 | 10:02 AM
aa1911's Avatar
very nice! I need to drop my crap runnin' boards....
Old Dec 28, 2010 | 10:19 AM
Your front dshaft will have mating flange on the tcase with studs as opposed to bolts and will have compatability issues with other dshaft flanges. You'll have to do some pattern matching and possibly do some flange swapping on the tcase and/or dshaft.
:wabbit2:
Old Dec 28, 2010 | 10:22 AM
monst's Avatar
good to know, ill keep that in mind. trying to find the path of least resistance.
Old Dec 28, 2010 | 02:08 PM
monst's Avatar
I think an 85 front drive shaft will bolt right onto the 95 4runner. can anyone confirm?
Old Dec 28, 2010 | 02:16 PM
The flange patterns are going to vary and the tcase flange has studs pressed in it, not holes for bolts.
Check. Plan. Measure. Don't assume it's going to be bolt on swap cause it won't be.
:wabbit2:
Old Dec 28, 2010 | 02:23 PM
4Crawler's Avatar
Might be the front shaft alignment is off due to the lift:
- http://www.4crawler.com/4x4/CheapTri...n-Measurements
If the alignment is off (i.e the bottom u-joint angle is greater than 0 degrees), then swapping shafts will not help. Either live with it, install manual hubs so you can unlock the front hubs if the front shaft is turning all the time, put a CV joint on the bottom or modify the differential mount to tip the pinion angle up more.
Old Dec 28, 2010 | 02:27 PM
monst's Avatar
I have manual hubs installed for this reason. I have also had a friend modify the dif mount to point it up, and that helped a lot. I just need to have it done a little bit more, just don't want to put to much more work on my mechanic. Ill get it taken care of, thanks for the advice.
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
TNRunner88
Jul 1, 2015 08:00 PM
