Sponsored by: CARiD
replacing rotors 94 pick up
Old Nov 30, 2010 | 10:10 PM
vincepower's Avatar
Gotta a 94 pick up 2wd and I went to change the front pads but decided that I also need to change the rotors. I was under the impression that the rotors simply slid right onto the stud but after removing my wheel it seems as though the stud is bolted to the rotor and it seems like this might be a pain in the ass job. Anyone have any tips for this job? Will I encounter problems getting this assembly off of the spindle? Will I have problems with the bearings?
Old Nov 30, 2010 | 11:58 PM
wyoming9's Avatar
Red face
remove wheel remove the caliper tying it up so it does not hang by the rubber hose
Remove wheel bearing remove hub remove the bolts holding rotor on hub . This is best done with a 1/2" impact . If you don`t have one a good vise and breaker bar
put the new rotor on put the hub back pack the wheel bearings
** At this time if you have new seals you may want to remove the inner wheel bearing and repack that as well.
Keep the new rotor clean or clean before installing new pads
Install the wheel bearing lock nut to the proper torque
Old Dec 1, 2010 | 12:27 PM
ALLDATAdiy INFO's Avatar
FormerVendor
Make sure you measure you adjust your wheel bearing preload and make adjustments.
Old Dec 1, 2010 | 03:22 PM
vincepower's Avatar
I don't know exactly what you mean by this.
Old Dec 3, 2010 | 10:34 AM
vincepower's Avatar
Does anyone know what the nut that holds the rotor/hub onto the spindle is supposed to be torqued to?
Old Dec 6, 2010 | 10:09 PM
vincepower's Avatar
Bearing preload
I had a thread on here a few days ago about installing new rotors on my 94 pickup 2WD. A few people suggested that I check and adjust the bearing preload while i do this. What exactly does this mean?? How to I adjust the preload? Does it have something to do with high tightly I torque the nut on the spindle that holds the rotor/hub assembly on? Please any clarification appreciated. I have a manual for a 93 pickup and the instructions for preload are not very good.
Old Dec 6, 2010 | 11:46 PM
dropzone's Avatar
Fossilized
No need for multiPle threads on same subject-
Merged threads
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
msane99
Jul 11, 2015 08:08 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
Jnkml
Jul 6, 2015 01:20 PM
