View Full Version : Newbie Tech Section
- Some ?'s about parking brake?
- Rebuild 22RE using engnbldr?
- What do I do to prep my new steering box?
- 1991 toyota 4runner someone cut the main knock sensor wire off
- buying a '90 4runner with blown hg tonight
- brake pad brand and rear main seal 97 Runner
- 1st gen 4runner, rear axle 4x4 problem
- Whistling whining noise, possibly from transmission
- Igniter Question
- What does this plug into?
- 33" tire lift clearance advice
- Lunchbox locker going out?
- stock 95 pickup 3.0 very high egts
- T-Case Spline questions
- Gas mileage?????
- 4runner won't start sometimes, engine stumbles then dies, starts with start spray
- Bumper Question from Mazda Owner
- Fuel pump won't work: 92 22re
- Swapping 3vze with another 3vze
- Dual Case - List of Parts
- 94 22RE maintenance recommendations
- 99 4 Runner pull to the left
- 1991 won't start - new battery
- How much lift do I need?
- flaring a broken brake line?
- my temp gauge goes up then back to normal but nothing is wrong?
- axle movement caused by worn out bushings
- Clutch issues
- thermostat
- Like Chilton or Haynes????Look
- 87 22r 5speed not getting fuel or even flooding?
- need exploded view 22re
- rear carseat trouble
- 94 4runner new automatic transmission shifting problems
- Thinking out loud...Building a dedicated hunting/firewood gathering 2nd Gen Pickup
- Best cheap mud terrain tire for stock height '91 Pickup?
- Have An 88 4Runner SR5 V6 What Other Years Engines Work In It?
- My 22RE needs a bath-suggestions?
- 89 fenders?
- Timing chain was last replaced???
- Whats the best motor choice
- Engine knocking
- compression
- Installing Engine
- 87 runner 4.3 vortec swap problems
- pressure plate question
- Junkyard wheels for my '91?
- Backlight question!
- how can i permanently block my radiator drain plug?
- Motor flush for 22RE prior to oil change?
- How to change clutch?
- Fuel light work?
- How to identify your engine 20r/22r/22re block and head
- How much will alternator put out?
- Buying a 3rdgen. Need help/advice/tips
- what tire size will fit my 98 4runner
- 1991 Pickup as daily driver/firewood hauler?
- 22re will not crank after head gasket replacement
- Best intake for 2.7l???
- tranny roblems
- Used Tranny - What to look for?
- How can I get some height without paying for a lift?
- 3RZ Question
- New 86 Pickup owner.. Questions
- Check engine light info needed
- 3rd Member Guru Needed
- First oil change for my 22RE
- 92 Toyota 4-Runner cranks but wont turn over
- 89 pickup wont start without long process
- I keep breaking my truck! Help me fix it
- just bought 1990 4runner.
- Hot idling
- Clutch Pedal Adjustment
- 99 4runner 3.4 hesitation
- '88 4Runner Paint; Single Stage?
- 1989 Toyota Pickup POOR Fuel Economy!
- Removing my 3 inch body lift
- Mysterious 22r Ignition/fuel issue
- Favorite Mod for under $250
- 92 tacoama 4x4
- Idle fine when engine is cold but not when warm
- pick up - tacoma roof racks got em - show em
- interior trim code h11
- dash
- How much boost can the stock ECU take
- 87 new clutch problems
- knock sound new engine :(
- Hesitation
- 90 3VZE truck starts and dies, wont stay running
- power steering?
- Battery keeps dying
- total chaos 6 lug uniball lt kit on 91 2wd
- 4runner vs. Hilux
- need help with the wiring on my 3.4 swap
- help 84 land cruiser fj60
- Tires
- 1993 v6 wiring brace near starter?
- T100 power steering doesn't work
- air flow meter replacement
- 4WD neutral - should the truck roll?
- 1986 Pickup interior mod
- Vibration
- Dumb question on ring and pinion kits
- Build 83 Toyota
- f70 axle ratios
- starter problems
- looking for cheap front/rear add a leaf kit for 1980 4x4
- Winter tuneup questions and ideas
- 1987 4runner exhaust header/mainfold
- Wheel Finishes
- dome light broken? How to fix it properly.
- Sunroof?
- Timing chain 22re
- what lockers is this
- Rear suspension noise after hard stop?
- throttle position sensor
- 92' V6 Toyota dies when I put it in gear
- 95 4runner, coupla questions
- no oil in my 88 pickup 3vze
- OIL IN MY RADIATOR - what does it mean?
- What grease for front axle?
- 84 pickup 2wd
- Will 15x10 MT Classic 2 from 91' Toyota Truck fit my 97' 4runner?
- Grizzly Lockers
- 1985 toyota pickup 22RE auto 2 w/d
- 22R Carb...need ideas
- NEWB Twin stick?
- Propane Parts sources?
- need a softer ride!!!
- 4x4 not working
- 22r head interchange
- Need Suspension Advice
- 89 4-Runner Transmission and Brakes
- 78 back from the grave.
- Torch Set found on EBAY
- 85 stock axle, biggest tire it can handle
- Are fr pickups usually more slippery under wet conditions?
- Trying to put my father in CPO 4 Runner, can you give me your collective advice?
- Fake ball joints, (pictures)
- Trying to help my neighbor
- tcase removal
- v6/turbo rear diff ABS plug?
- Driveline Brake
- VAFM sounds bad
- 22re timing chain and head gasket
- Please help me someone!!!!
- 1991 22re missing and constant high idle
- Manual Transmissions offered in Xtracab between 1999-2001?
- 1st gen 4runner Rear window not working
- '86 pitman arm problems
- has anyone put power steering on a 79 pickup?
- Get More power from my engine
- 85 4runner runs poorly when any accessories are turned on
- Failed emissions with high CO HC readings. HELP?
- 15x8 or 15x10 for 35s
- I over tightened rear brake ajuster
- 92 V6 PU Cruise Control No Go...
- carb trouble 22r
- yota gets hart but just wont go
- Propane
- need small lift in the rear, blocks okay??
- Bolt Patter for 2011 series 71 landcruiser anyone.
- Truck won't go into 5th gear
- Pickup: parts for a 79 in a 78?
- New Guy with some 4Runner Electrical problems
- carb adjustments
- 22r carb problems i think ???????
- 79 pickup fuel pump bad?
- Recommended (or best) Manual Locking Hubs
- 2WD to Solid axle 4x4
- Help with crackling noise
- Durable front bumper?????
- Left front Suspension Wheel hop 94 4run
- runs fine won't idle and dies
- 22 RE valve cover interference
- Multiple problems or One big one?
- 1986 XTra Cab swap
- wiring help: 83 Toyota
- when put in drive it acts like it wants to go but has no power
- What to do before alignment?
- Gear swap now vibration
- CAT flange look right?
- Hilux, sr5, truck clarification needed please
- engine swap
- Yup I'm a newb and find my prob with the search button.
- 1990 Toyota Truck steering rod recall info?
- 1990 V6 pickup coolant help please
- Anyone running aluminum wheels?
- Dropping tranny tonight
- newbie to painting
- 91 4runner v6 auto harness number 82121-89297
- 87 Turbo randomly dying
- Low on oil but not really?
- carb
- ticking r22
- newer engine installed... flexplate too far from TC
- kinda confused on motors
- can a snorkel be put on a daily driver?
- Hello from NWI!
- 7.4 mpg problem!
- Moon Roof Won't Seal
- 3RZ swap question
- 4lo, 4hi, d, 2, L
- Timing guide rails, steel or plastic?
- Senior project on my first car?
- 1987 xtracab 4x4, factory locked in front?
- 3.4L or 22reTurbo? What would you do?
- Loss of powersteering at idle after highway speeds.
- Easy newbie brake question!
- Where can I buy battery cable extension wiring?
- Curb check alignment problem
- Oil leak with pictures
- gears set
- Air bags above leaf springs
- Does a Gen3 rear axle bolt up to a Gen2
- brake rotors
- engine replacement
- Buying: What To Look For..?
- towing capacity 93 2wd 3slow?
- 1989 toyota pickup
- $1900 for elocker regear X2, and rear axle seals?
- Toyota fasteners
- 1990 22r with a lot of gas in the oil..
- synthetic gl-5 in the axles
- Steering column compatibility
- 04 tacoma 3.4 motor and trans into 1997 tacoma v6 sr5
- Looking to make my pickup more offroad capable
- Intake Manifold Studs
- Mystery Hose
- U bolts
- 94 v-6 pickup temp sensors
- Airbox compatibility?
- Tacoma Grill/Lights compatible with T100?
- Which way does O2 sensor gasket go?
- Spring compatability?
- cast iron vs aluminum master brake cylinder?
- Rattling in lower left hand side of motor
- T100 custom bumper
- What would you recommend???
- 93 4Runner Intermittent Transmission Problem
- trying to guess expected mpg from potential 4runner purchase
- running on back two cyinders
- wiring my 91 4 runner to tow
- wont start when warm
- Rear axle
- Switching Electric to roll up windows?
- Leaking rear end, woes...
- 5.71 gears with 33 12.5
- Headlight Switch Issues
- Best tacoma lift set up?
