Sponsored by: CARiD
22r carb problems i think ???????
Old Sep 28, 2011 | 05:18 AM
camotow's Avatar
Question 22r carb problems i think ???????
hey guys im new here anyway i have a 87 yota 4x4 with the 22r heres whats up with it i got her done 4 days ago im having trouble starting her in the mornings or after it has cooled completey off kinda like its not getting gas i have to pour a lil gas in the carb to get her started but then it runs fine and strong and will idle all day long very smooth and it will restart after that first warm up but it still wants to spin over more than id like for it to crank but will crank with out gassin the carb
. i just bought the truck about a week ago it had been sitting for almost a year because it had jumped time so i trailered her home broke her down and put a new timing chain set in it (not my first time doing this) i tuned it up new wire plugs filters and sum vac lines that looked dry i also changed the fuel pump yesterday and no help to my problem this morning ................. so if anybody has ever experienced this problem please let me know how to fix this . thanks alot
Old Sep 28, 2011 | 05:24 AM
richard212's Avatar
try fuel filter
Old Sep 28, 2011 | 05:34 AM
camotow's Avatar
i already changed the filter two days ago and didnt help
Old Sep 28, 2011 | 05:43 AM
richard212's Avatar
make sure you have good spark, fuel pressure and volume
Old Sep 28, 2011 | 05:44 AM
richard212's Avatar
you have to adjust the valve clearance on that engine every so often. Is it possable that valve timing is so out of wack that it is not building up compression or the valves are opening or closeing late
Old Sep 28, 2011 | 05:59 AM
camotow's Avatar
Valve clearance
. not sure I haven't adjusted the valves it doe have a good chatter to her when she running
Old Sep 28, 2011 | 06:07 AM
camotow's Avatar
When the truck isn't running when I accelerate carb shouldn't I see gas spray ??
Old Sep 28, 2011 | 06:08 AM
richard212's Avatar
i dont think so cause there wouldnt be any pressure cause nothing is sucking
Old Sep 28, 2011 | 06:20 AM
camotow's Avatar
Idk. Once it's started u can drive it just about anywhere and it never skip a beat
Old Sep 28, 2011 | 08:04 AM
camotow's Avatar
It is running rich also
Old Sep 28, 2011 | 08:38 AM
yoterr's Avatar
When the truck has cooled off check the sight glass and see if you have fuel in the bowl...if not u may have a leaky jet that empties the bowl over night. Also you should see a spay of fuel when you pump the accelerator.... and if you can do a timing chain you can rebuild the carb...pretty simple
Old Sep 28, 2011 | 09:03 AM
camotow's Avatar
I have another carb off old engine that came out truck bout two years ago. Should I try it ?
Old Sep 28, 2011 | 12:01 PM
richard212's Avatar
It's worth a try
Old Sep 28, 2011 | 12:02 PM
camotow's Avatar
It's worth a try
It made no difference what so ever
Old Sep 28, 2011 | 01:48 PM
richard212's Avatar
Really dang could be the valves then
Old Sep 28, 2011 | 06:53 PM
camotow's Avatar
Changed carb
Ok I changed the carb I had another on the engine that came out this truck two years ago. So I put it on and seems to be starting better but the flood smoke is awful now I let it set a few hours and this carb is holding the fuel in the bowl the glass is a lil less than half full ??
Old Sep 28, 2011 | 07:49 PM
streetlancer's Avatar
Your choke aint workin properly, probably a busted diaphram.
Old Sep 30, 2011 | 07:15 AM
camotow's Avatar
ok guys idk what the crap to do now i got her starting good in morning or hot but now i have alot of white smoke or maybe its grey im not losing water or oil neither is either one mixing with the other and i have good compression any ideas on this now
young buck
18
Aug 27, 2018 02:40 PM
skoti89
Sep 11, 2015 07:46 AM
keithporter83
Jul 24, 2015 07:37 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
