Sponsored by: CARiD
Multiple problems or One big one?
Old Sep 25, 2011 | 09:44 PM
Jeremy_C's Avatar
1990 Yota 22re 4x4. At start up, the idle is around 12-1500 rpm and smooth. As the truck warms, the idle drops. At operating temp the idle falls below 500 and acts like it wants to stall. The shifters vibrate like crazy the idle is so low.
Thats one problem
While driving it feels like there is a very small miss, complete tune up with in the last two months, and it was doing this before hand. Sometimes its more noticiable then others, but its there.
It acts as though its loading up with fuel...there is a raw fuel odor coming from the truck from the exhaust.
Could this be one large problem, or several small problems? I've searched, but nothing with all 3 of my problems together. I can probably be alot more descriptive if i need too but right now the pain meds are starting to kick in.
Old Sep 26, 2011 | 12:43 AM
wii_tarded's Avatar
How old is the cat? I could be clogged, or even a vacuum leak causing the low idle.
Where in E. Tenn are you? I live in north K-town.
Old Sep 26, 2011 | 09:50 AM
Jeremy_C's Avatar
Its probably factory....I dont think previous owner replaced anything. I'm in Lafollette, Campbell county....Right up 75 from you
Old Sep 26, 2011 | 10:17 AM
4Crawler's Avatar
Likely the fuel and rough running issue is that the fuel pressure regulator is not getting proper vacuum at idle. There is a vacuum line feeding a VSV that feeds that to the FPR. Check it 9or bypass it:
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/8.html
W/o the vacuum like, you get full fuel pressure at low engine load and that causes too much fuel to be injected and it runs rich and loads up until you hit about 2000-2500 RPM.
Old Sep 26, 2011 | 10:58 PM
Jeremy_C's Avatar
That seems like it would cause the idle problems as well. If the Cat is stopped up, along with the fuel pressure would that result in a loss of power? Its a 4 banger, so as you all know there isn't much power to loose.
Old Sep 27, 2011 | 01:59 AM
IngSoc's Avatar
Try unplugging your TPS and see if itr runs better. Most my issues that sound like that either were the TPS or the MAF(AFM w/e)
Old Sep 27, 2011 | 04:53 PM
Jeremy_C's Avatar
I'll try that..... I'll search around and figure out how to do that. My first toyota, so i'm learning as I go.
young buck
18
Aug 27, 2018 02:40 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
wilbertd
Jul 6, 2015 07:39 AM
