Sponsored by: CARiD
Rear axle
Old Sep 10, 2011 | 04:40 PM
joeymmeezz's Avatar
Rear axle
what rear axles (year) would fit on an 84 4runner
Old Sep 10, 2011 | 05:00 PM
myyota's Avatar
Anything from 84 - 85 truck or 4Runner should work. 86 and up wont work because they made the rear ends wider, so the axles would be to long.
Old Sep 10, 2011 | 05:45 PM
dropzone's Avatar
Fossilized
79-85 will fit if you are looking to just replace the axle itself or the entire housing
swapping the complete housing from an 86-95 does gain you 1.5" in width on each side and bigger rear brakes, early brake drum on the left, later IFS rear end drum on the right, bigger brake = better
you would just need to run 1.5" wheel spacers upfront to get your track width to match.
very common swap
Old Sep 11, 2011 | 08:34 AM
joeymmeezz's Avatar
I found an 87 im going to need wheel spacers correct?
Old Sep 11, 2011 | 10:09 AM
4Crawler's Avatar
Not required, you can leave the front as it is and the rear will be 3" wider. Or you can add the spacers up front if you want the f/r track to be equal. I ran almost 10 years with a narrower rear axle than my front.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
yourrealdad
Jul 21, 2015 11:13 AM
toyoda8488
Jul 5, 2015 10:18 PM
