Sponsored by: CARiD
87 Turbo randomly dying
Old Sep 23, 2011 | 11:01 AM
JBrian01's Avatar
No rhyme or reason, happens often - the truck just dies, it seems electrical as there's no sputtering or anything, just dead. Then it'll start, but it usually has to sit for awhile, though sometimes it'll start again right away.
FWIW it has 340k on the chassis, and some rust and corrosion, so the chances of a bad ground or electrical problem is high..
Any ideas?
Old Sep 23, 2011 | 12:06 PM
gorillaman2012's Avatar
how long does it run before it dies? are you able to drive it a while before it dies? does it die while idling or while driving. are you pulling anything with it when it dies? did you just recently put gas in it?
Old Sep 23, 2011 | 12:16 PM
JBrian01's Avatar
Im not towing anything, and it has had fresh gas put in it from an empty tank.
It usually doesn't make it very far - maybe 5 miles.. Usually long enough to barely warm up. I haven't tried taking it on any long trips for fear of dying on the freeway..
Bad voltage regulator?
Old Sep 23, 2011 | 01:12 PM
im thinking fuel issue. figure out what your fuel pressure is then go from there.
Old Sep 23, 2011 | 01:52 PM
Philbert's Avatar
Sorry your truck is giving you issues - good luck!
If you give up and decide on an engine swap...let me know if you want to part out with the turbo thermostat housing?
Phil
Old Sep 23, 2011 | 04:57 PM
JBrian01's Avatar
If it was a fuel issue, wouldn't it tend to sputter as it dies? It doesn't sputter at all, it's just like killing the ignition..
Phil
Not gonna part it, but I'd consider selling it - 80k rebuild by a toy tech, this is the first problem I've had with it..
Old Sep 29, 2011 | 01:52 PM
Allan M's Avatar
My 87 does the same thing , I swaped out the ignition mod and the coil seams to help so far . If possible get a used one I did and didn't want to spend the $600.00 for the modual alone . how much do you want for it if you deside to sell it ?
Allan
CPD4runner
9
Nov 5, 2017 06:01 AM
shisha1999
Mar 3, 2016 07:09 PM
viesail
Sep 21, 2015 06:00 AM
Gutted91
Sep 17, 2015 05:44 PM
shalom
Sep 8, 2015 10:02 PM
