Sponsored by: CARiD
99 4 Runner pull to the left
Old Oct 28, 2011 | 12:47 PM
Revbrent's Avatar
1 month after a 2 inch lift to my 99 4Runner I replaced the front pads and rotors. Afterwards there begain a pull to the left when braking. I replaced both calipers and it did not fix the problem. I took it into a shop and they swapped the rotors and pads around and nothing changed. They concluded it was in the ABS Control. I swapped out the ABS control unit with no change. The shop said the front end was tight. And it was not suspension or steering. It does not matter the speed...the pull takes place by slightly tapping or applying pressure to the front pedal. Initially it pulls left. I took it to a new shop and they noticed the left caliper was hotter than the right and so replaced the left caliper with no change. They issolated the rear from the front with no change to the pull from the front so eliminated the rear. Please help!!!
bigblue82
10
Jul 6, 2015 08:27 AM
miceal383
Jun 29, 2015 12:27 AM
saphirekosmos
Jun 22, 2015 10:26 AM
Mr.Black
Jun 21, 2015 10:17 AM
JaredL
Jun 16, 2015 04:47 PM
