Sponsored by: CARiD
Timing chain was last replaced???
Old Oct 26, 2011 | 05:37 AM
Badfish740's Avatar
I know at some point the engine was either rebuilt or replaced in the truck I currently own ('91 Pickup with 22RE). I'm not sure exactly when-the truck has 160K on the clock and my best guess is that the timing chain let go around 90-100K, but that could be off. If I'm right, the current chain has been on for about 60K. What is the timing chain change interval?
Old Oct 26, 2011 | 06:02 AM
waskillywabbit's Avatar
Typically 90-120k or when it starts clanking.
:wabbit2:
Old Oct 26, 2011 | 06:20 AM
pruney81's Avatar
Mine is on the original chain and guides at 144K miles. This is with the driver side guide broken at the top bolt hole since I bought it at 95K miles a little over two years ago.
I think I will get around 200K out of mine. I would pop off the valve cover and take a look and decide whether or not you want to replace it. If everything is intact and it's not making any noise I wouldn't worry about it.
I'm not recommending to run it like I have mine, it's probably best to replace it if it's broken but I have put around 50K on mine in two years like I said and it hasn't got any worse.
I just use rotella 5W40 T6 and change it every 3K miles. I think a good, thicker oil helps.
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
Badger62811
Jun 26, 2015 09:26 PM
Taz22R
Jun 21, 2015 04:44 PM
paxanders
Jun 21, 2015 06:29 AM
