Sponsored by: CARiD
engine swap
Old Sep 24, 2011 | 09:14 AM
racenjoe420's Avatar
Question engine swap
i have a 86 toyota 4x4 with a 22re engine. i wanted to swap it out with another 22re engine out of an 84 toyota. the question is my 86 is a manual and the engine that im putting in is out of an automatic. i just wanted to make sure that the engine would bolt up to my manual tranny.
Old Sep 24, 2011 | 09:48 AM
mightymouse's Avatar
where did you find a 22re out of an 1984 toyota? (reason i'm asking is that 22re's were not available in toyota 4x4's until 1985 only the 22r) If it is indeed a 22re it should work fine. Or if you're just swapping 22r's it should work as well. This is in regards to long block to long block. Other stuff like wires and plugs might be a little different.
On another note be aware the 84 block and head is different than the 86 block and head. Do some research and know before you start what you're getting into.
Old Sep 24, 2011 | 09:31 PM
it is an 85 that was my fault. i bought it for parts only. its an 85 automatic 22re and my truck is a manual.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
