Sponsored by: CARiD
85 4runner runs poorly when any accessories are turned on
Old Oct 1, 2011 | 04:42 PM
OhBoy's Avatar
Exclamation 85 4runner runs poorly when any accessories are turned on
Oh Boy another newbie.
OK that said.
1985 4runner Non turbo runs poorly when i turn on headlights,fan,wipers,etc.
New cap,rotor,plugs,plug wires,battery.No Check engine light.Seems to be charging just fine with 14.2 volts measured at the battery.
Old Oct 1, 2011 | 05:02 PM
gary_the_4runner's Avatar
i would check for loose connections first, make sure you have it grounded properly. is your battery underpowered? what else is directly connected to your battery besides what is factory?
are you reading 12v on the alt when the key is ON (not running)?
i know i sound like troubleshooting for dummies but info provided would only point to this... and sometimes its something insanely simple.
Old Oct 1, 2011 | 05:36 PM
OhBoy's Avatar
Yes I have grounded it well and even ran another ground wire from battery to the fender well.the new battery is 12.82 or so with the key in the on position terminal are clean and tight.the battery has 650 cca.No other items are going to the battery Radio,etc.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
alfonz33
9
Nov 16, 2015 09:21 AM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
serenity03k64
Jun 27, 2015 07:59 AM
WI Girl
Jun 25, 2015 03:45 AM
