Sponsored by: CARiD
How to identify your engine 20r/22r/22re block and head
Old Oct 24, 2011 | 03:18 PM
xxxtreme22r's Avatar
Mods please make this a sticky. Kinda getting tired of cut and pasting from LCE's FAQ page. lol. Will add photos for those who don't know how to read.
Cylinder Head Identification
1975 - 1980 20R Cylinder Head
Round Intake Port
Round Exhaust Port
80/81 C.C. Chamber
Intake Valve Diameter 43mm
Exhaust Valve Diameter 35mm
Dual Row Timing Chain
Domed Pistons
Steel Rocker arms
1981 - 1984 22R Cylinder Head
Square Intake Port
Round Exhaust Port
82/83 C.C. Chamber
Intake Valve Diameter 44.5mm
Exhaust Valve Diameter 36.5mm
81-82 Dual Row Timing Chain
83-84 Single Row Timing Chain
Domed Pistons
Aluminum Rocker Arms
1985 - 1995 22R-22RE Cylinder Head
Square Intake Port
Pear Shape Exhaust Port
52/54 C.C. Combustion Chamber
82/83 C.C. Chamber (Turbo) Intake Valve Diameter 44.5mm
Dished Pistons
Engine Block Identification
1975 - 1980 20R Block
Deck Height 11.280\"
Stock Bore 88.5mm - 3.484\"
Domed Pistons
1981 - 1984 22R Block
Stock Bore 92.0mm - 3.622\"
Domed Pistons
1985 - 1995 22R-22RE \"Laser Block\"
Deck Height 11.090\"
Dished Piston
Old Mar 24, 2013 | 10:16 AM
aquafbody's Avatar
I have a plack on my firewall that says 22rec. What is the C?
Old Mar 24, 2013 | 11:49 AM
SCToy's Avatar
California smog equipped i believe.
Old Jul 21, 2013 | 10:11 AM
ToyX2's Avatar
It may be true but I'm not 100% sold on that yet, the 85 fsm makes reference to the 22R-EC engine under the electronic control section, I assume EC standing for electronicly controlled. Also the auto parts stores that I have been to only list parts for 22r or 22rec, no 22re. If the C in rec stood for California why isn't there a 22RC? Also, at least on the early 22re's they might actually have less smog stuff on the Cali models then the federal/Canada models, like no air injection tubes on the exhaust manifold.
Old Jul 21, 2013 | 10:14 AM
SCToy's Avatar
There is a 22R-California model.
I am currently looking for a new Emission Control box for my 81 and guess what, it's year AND California specific. The motor may be the same, but the electronics on the carburetor aren't.
Old Jul 21, 2013 | 01:43 PM
ToyX2's Avatar
I'm aware of the fact that there are california emissions vehicles and federal/Canada models, I believe it's noted on the under hood emissions sticker. Having some different components I can understand needing a different brain, I'm just not sold on the C in rec being for Cali, I've seen the question come up a bunch but it always seems like a guess and not a fact. Why would the parts stores not have both 22re and rec options. Also online you will see people saying the C is for a bunch of extra Cali smog stuff, but from what I've seen there is not a bunch of extra smog stuff at least not on the early efi motors. Maybe the carbed models, I don't know?
This is getting off subject so let me ad that the early blocks, pre 85, also have the teq logo cast in the block on the exhaust side. As far as I know it's not on the later blocks.
Old Sep 2, 2013 | 09:08 PM
Boxcutter's Avatar
deleted
Old Nov 21, 2013 | 07:39 AM
Mason155lbs's Avatar
The 22R is a carburetor engine
And 22RE is a fuel injected engine\
and a 22RTE is a turbo. . .
Am I Correct on this?
Old Nov 27, 2013 | 08:43 PM
old87yota's Avatar
Yes, that is correct!
Old Mar 7, 2014 | 05:52 PM
jicko's Avatar
Ah T = turbo
Old Jul 6, 2014 | 05:33 PM
Jimmydean419's Avatar
Here's one for ya guys. I got a 22r. Single row timing chain. Exhaust ports are round but have a small hole above them. Carbon makes it look like the exhaust manifold was pear-shaped. The Pistons are domed. is this an 83 or 84 block when they change it to the single road timing chain. Can I put a 20r head on this block and change it to a double road timing chain. Ty for any help
Attached Thumbnails How to identify your engine 20r/22r/22re block and head-image.jpg
Old Jan 22, 2015 | 10:16 AM
4crawled's Avatar
I'm in the same boat I have a 22R and want to put a 20R head on it, like this page here..
http://tinyurl.com/kpsshnp
But im not sure what year 22r I have.. pre-83 or 84.. can I turn this into an EFI engine? Most of the identification on this post is not present on my motor.. help?
Old Jan 22, 2015 | 05:13 PM
ToyX2's Avatar
You should start a new thread and include pictures. I don't think the factory efi mounts up to the 20R head, 22r head yes.
Old Jul 10, 2016 | 08:33 AM
GeoffG's Avatar
In parts stores only some parts are california spec o2 sensor and other emission related. in Canada Ive never had options as california is the hardest place to smog
Old Jul 10, 2016 | 02:24 PM
ToyX2's Avatar
That depends on the vehicle and year. Speaking only about the early 22re the emissions diagrams for federal/Canada models actually have more smog crap.
Old Jul 31, 2017 | 08:02 PM
chawixtle's Avatar
hello, new member here
Got a78 2wd pickup, the sticker on the valve cover is faded and the badge on the fender says its a 20r.
took the carb to a shop to get it rebuilt or a new one and the guy saw it and right away said, thats for a 22r, and sure, went back to browsing and yes, its a 22R...
how do i know which 22R I have, if in fact it is a 22R?
Old Aug 2, 2017 | 06:52 AM
ToyX2's Avatar
Look around on the block for a casting that says either 20r or 22r, possibly drivers side. As far as the carb I read that the 20r carb is round on top as apposed to square on the 22r carb.
Old Aug 22, 2017 | 01:22 PM
chawixtle's Avatar
thank you.
Its a 22r.
is there a way to find out the year?
when i went to the parts store to buy spark plugs i did not know what year to ask them for
Old Aug 24, 2017 | 08:50 PM
ToyX2's Avatar
Originally Posted by chawixtle
thank you.
Its a 22r.
Earlier in the thread there's some info and I think a picture that tells how to i.d. the 85-95 block. I'm not sure but I would think the spark plugs would be the same regardless of year. I suggest NGK.
For reference showing one plug fits all..
http://www.lowrangeoffroad.com/toyota-22r-22re-22rte-genuine-oem-spark-plugs.html
Old Sep 30, 2017 | 11:07 AM
badgef's Avatar
Well lets try this again , I have a 22re block and a20r head on it now is there a differance between the head gaskets, I have a heating problem,, is there a difference in the water ports?.
