View Full Version : Newbie Tech Section
- 3rz crank but no start no spark
- Frame rust should I buy or run away.
- Different oil pan bolt sizes
- 91 pickup coolant pouring out exhaust manifold.
- 22re Head gasket advice
- Overheating
- Egr crossover plate leaking coolant bad
- RAD4runner question
- Drive spline Installation Depth?
- Output shaft r150f trans. Trying to build this trans.
- Needs tie rod ends, but what do I have?
- Differential lockers? Yes or no for my truck
- Coolant l als after full rebuild
- Drop drag link help
- Headlights not working
- 93 3.0 V6 hesitates and stalls
- Fixing a 3rd gen 2002 4 runner 4x4 timing belt and water pump
- No overdrive when it is cold outside
- Engine Hardware Grade?
- wheel seals
- 1993 22re rattling noise
- L43 Side Shifter Question
- Knocking 22re help!
- Forgot to pack the oil pump with grease.
- 1981 SR5 4x4 Pickup / carpet kit
- What is going to be more reliable / cheaper
- Repair shops in the Maryland/DC Area
- 22re Water Pump Leak
- Introduce myself and tech question..
- 4WD not working properly
- What are these numbers on top of my 22re pistons?
- Location on VIN #
- 94 4runner Intermittant Start Code 52, 12, 22
- Will these wheels and tires work on my 1990 Toyota Pickup Standard Cab? Please help
- 91 Pickup 22RE - burning oil?
- 22RE rear allen bolt near crankshaft?
- 20r MSD 6t installation help
- OEM pistons or new dnj
- 96 4runner 3.4 V6 timing questions
- Fuel Tank cross compatibility w/ 79 Pickup
- Loose wire ends under dash on '85 questions
- Can someone tell me what kind of knock this is?
- How to get front diff back up
- 88 pickup high side AC line to condenser
- Add clock light to dash cluster illumination
- Analog clock wiring ?
- Carburetor rebuild
- Will an 84 standard bed interchange onto a 91 standard pickup?
- What is this ?
- Engine cold start
- Adding longer leaf springs
- Starter RELAY location
- 1989 Toyota pickup, water from exhaust manifold. Help if you can?
- Engine power issue on new rebuild
- 1KZ-TE poor fuel mileage and black smoke
- thinking of buying a 94 4runner w/ a 3.0L v6. any negatives to this engine?
- Funky noise
- Newbie ‘95 Pickup 4x4 3.0L V6 looking for advice
- Apple car play
- Toyota Odyssey - 1985, motorhome, small repairs needed
- 96 t100 auto no reverse
- Carb rebuild
- 97 4runner front diff not engaging
- Need help. Running fine....5 min down the road truck dies can't restart
- Installing a 1975 celica motor in my 1994 pickup
- Pinning for Tach in 84-88 4Runner gauge cluster?
- Electrical Cut Out While Driving
- 94 T4R 22re ticking and occasional rough idle help
- Newbie Introduction and a question
- Poor brakes after replaced differential seal
- W56 Transmission Rebuild Kit?
- Crank shaft pully wont stop
- Newbie with problems and questions
- Full engine computer conversion
- Please help! Dire straits here
- 82is really an 81?
- 1990 4Runner with SAS swap
- OME leaf spring question.
- Flange yoke
- A/C ThermoSwitch on 1983 Toyota Pickup 4x4
- 3rd member
- Retrofitting Newer Radio Into Older Pickup
- 1st gen pickup bumpstops
- Cam spin?
- 95 toyota 4runner 3.0 by no spark
- flywheel replacement... bolts came loose
- tranny blown??
- oh boy, another surging idle issue!
- Code 52 smog issue.
- Rear diff locker question 99 4runner
- 96 5vz-fe vacuum hose locations
- Accessory Power
- pulling to one side when breaking hard
- Power steering
- 3.0 engine
- Been having this idling problem for a while.
- 1980 Toyota pickup 4x4 rust repair
- Mechanic recommendation for San Fernando/North Hollywood
- 22re to 22r swap questions
- Efi missing
- 5vz exhaust manifold swap
- 2002 Tundra 3.4L timing belt replacement ?
- 01 4runner Long Travel 2wd p0500
- Rear leaf spring identification
- Fuel gauge not accurate
- 22re running rich
- Ac button not lighting up
- Ignition and door key upgrade?
- engine swap no start 22RE
- Brake upgrades
- 14b Diesel info wanted.
- I'm trying to solve a battery or charging issue. 97 T-100
- 22r drives like it’s pulling big tires
- 22R / RE compatibility
- Valve Job???
- 2wd Pickup rear bump stop - Need Help
- 1st gen 4runner top weather stripping.
- Blown head gasket
- ABS brake conversion upgrade
- 1992 4x4 frame compatibility.
- 84 22r Toyota pickup 4x4 firing issues
- Wire from igniter and green relay?
- Simple EGR delete and vacuum quest
- 99 limited 4 runner- the cabin fan not working
- 1993 pickup with 3.4 stumbling and jerking
- Tie rod removal tool
- Electrolysis, Ground Wires
- Weber 38 DGMS
- 1990 2wd Pickup replacement suspension
- Horn problem
- Rims fit?
- 1987 Toyota 4Runner 22re green electrical plug under intake
- Need help identifying!
- 3vze bogging down with acceleration- HELP
- Rear frame repair under bed
- 5VZ-FE Engine trouble after installing Supercharger and performing multiple repairs.
- Wet black soot from exhaust
- what gauge fusible link wire 1983 2wd
- Manual to auto help
- RN101~N018XXX Chassis ID
- Stuck in 4wd
- need help please with wiring
- need help please
- 3vze stalling while driving, loss of power.
- Need a quick answer!
- 4runner 4x4 not engaging
- 4WD, cruise control, and overdrive not working
- Anti theft is malfunctioning
- '89 Pickup 22R Screwed Up Timing
- Hydro-locked With Floodwater 22re 1993
- Random hesitation until 3500ish
- Just need some insight
- Hard Starting after warmed up
- Throttle body 95 runner
- Newbie purchasing
- NOOB Is there a 1st gen Tundra area?
- New Toyota Owner!
- First motor build ever - Thread
- Stuck on Crankshaft removal
- Intake manifold Studs
- Transmission mount
- 1990 with 115k miles
- A340H to A340F on 22re?
- Where is fill hole on A340h transmission?
- Best place to buy a new rear diff
- Brakes overheated, new calipers and rotors.. what the?
- I messed up - removed head without being at TDC on compression stroke
- 93 v6 toyota pickup burnt ecm up
- How bad is this??
- Crooked compression fitting on fuel line
- H6054 SYLVANIA Headlights won't fit?
- rim size
- Cost for mechanic to fix leaking fuel injector
- Vacuum Line from Fuel Tank MIA
- Coolant coming up out of rad right after starting
- 3.4 Swap ecu questions
- 1988 3VZE 4Runner CEL code?
- Confused on timing chain with HG replacement
- Head Gasket Replacement Failure
- Engine Swap??
- How to test 3VZE temp sending unit
- ECT, where are you?
- EGR mystery
- Timing Cover Leak - 3 Bolts Missing (AC Compressor Removed)
- Gas tank pressurized
- 93 22re starts ok, runs for 3 seconds, runs rough, dies
- Can't tell if 4x4 is engaging...?
- Grinding coming from right front
- Windshield Info
- Any ideas to what this plug is for?
- Water inlet/outlet gaskets / back of timing cover?
- Machine work
- My first compression test 3VZE, what do y’all think?
- Broken chain guides: should I change timing cover / remove oil pan?
- Are my piston rings shot?
- 02 V6 tundra stalls
- Odometer not working
- 93 pickup V6 3.0 timing issues
- Smoke upon startup
- 91 Toyota pickup 22re code 31
- Ok need advice on a new 3.4 Toyota motor.
- My only vehical
- 22 re exhaust configuration recomendations California
- Wheel fit
- 91 toyota pickup windshield wiper linkage
- Hard starting after warmed up
- Need to know a part name, thanks
- Car not starting after heavy rain
- Blowing coolant out the reservoir
- timing chain rubbing on cover first start up after complete rebuild
- 22re complete head vs just gasket replacement?
- 1981 Pickup Door handle to latch rod clip-Where to purchase?
- New Engine blowing main fuse (80A)
- senror location?
- First attempt at shock replacement
- 92 pickup spindle bearings....
- Best way to find out vehicle history?
- Front cab mount issues
- Corrosion inside fuse?
- Is anyone familiar with Sprint Booster?
- Should this be replaced? Buddy says no
- 3VZE alternator replacment
- 2005 Land Cruiser- buy or no-buy?
- Fuel line broke 2005 Tundra
- 1994 Pickup will not shift into gear
- Cold start/fast idle question (auto trans)
- Best way to upgrade my 88 Pickup 4wd?
- 1994 3 VZE, Code 14, Code 52
- Grills
- Cranks, have spark but no startWhat
- Idles fine but very poor acceleration
- 22re Valve Cover Gasket
- 3VZE fuel pump check valve
- Replacing motor, and transmission
- 3rz Rod Orientation
- Steering Extension Placement
- 5VZ-FE idle and engine pulse issues
- 89-95 4runner tail pipe bracket
- 95 4runner
- engine install
- Help
- Tailgate
- Door lock knob mystery
- 1990 camry 2VZ FE high idle problem
- Need wiring Diagram for this.
- Aftermarket Exhaust???
- 22re intake leak
