Sponsored by: CARiD
Engine cold start
Old Oct 14, 2019 | 05:54 AM
Gillew's Avatar
Engine cold start
Need help. I have a 91 pickup with 22re. I have had trouble with a rough idle. Got that issue fixed now having trouble with a cold start to idle. When engine is warm cranks fine. But when engine is cold engine turns over and tries to start. You have to continue to turn engine over. I need some help could it be cold start injector?
Old Oct 17, 2019 | 07:26 AM
old87yota's Avatar
Welcome!
You could have a bad cold start injector, but the more likely suspect parts are going to be your cold start injector time switch, or possibly the ECU coolant temperature sensor.
You will need a multimeter to help you determine if your sensors are working correctly.
The fine folks at 22RE Performance created an FAQ page that includes a long crank time when cold problem and includes testing the cold start injector time switch. It is about 2/3 down the page here: https://22reperformance.com/faq-diagnostic-info
crawler nub
Nov 19, 2013 04:34 AM
mmcpeck
Dec 21, 2010 09:08 AM
axle09
Feb 8, 2010 10:37 AM
markg
Jun 15, 2009 10:56 PM
