Sponsored by: CARiD
Cam spin?
Old Jul 21, 2019 | 01:43 PM
swampedout's Avatar
5 Year Member
Cam spin?
Hey folks,
I'm rebuilding a 20r after blown headgasket. I'm putting it all back together and I have question about the cam: I have the cam lobe bolts torqued down with assembly lube on the cam. With the rocker assembly off, when I try to turn the cam by hand, it is frozen in place at first then will spin with a little drag on it. Kinda feels like a bolt that you need to crack before it frees up. Does this make sense? Should my cam have the initial resistance before spinning?
I'm so close to getting this bad boy together....
thanks
Old Jul 21, 2019 | 06:11 PM
Melrose 4r's Avatar
5 Year Member
Is it the same cam you were running or a brand new cam?
Old Jul 22, 2019 | 07:56 AM
swampedout's Avatar
5 Year Member
same one. i havent changed anything up there.
Old Jul 22, 2019 | 08:04 AM
Melrose 4r's Avatar
5 Year Member
Somebody correct me if I am wrong but I believe the cam journal caps are numbered 1-4, front to rear. If that's the case and you have them in the correct order, no worries.
Old Jul 22, 2019 | 05:53 PM
swampedout's Avatar
5 Year Member
Yea thats how i have them. 1-3 however...
edeslaur
Aug 19, 2013 09:29 AM
ravencr
14
Mar 10, 2010 04:24 PM
Flygtenstein
May 9, 2004 06:57 AM
03TundraTRD
12
Sep 7, 2003 04:44 PM
