PDA
View Full Version : Newbie Tech Section
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55
  1. Where does my OBD II plug in at??
  2. Frame repair
  3. High idle at cold start
  4. Will these tires fit?
  5. Simple Question: OME springs and stock shocks
  6. Strange tick
  7. Idling rough- Need a little help
  8. Thinking about buying another Toyota!
  9. 95 4-runner rear suspension change
  10. Funky smell on startup
  11. 1972 Celica ST 18R change to 22R
  12. body lift
  13. Need help with finding headers and full exhaust system
  14. Gauges
  15. tire swap for mileage
  16. Is this possible
  17. What should I do before I swap my 22re
  18. turbo ? ct20 to ct26
  19. How dangerous is this, replacing a sleeve with cold weld
  20. Elocker...8" to elocker housing
  21. new to 4x4in
  22. confused need help!!!!!
  23. o2 sensor ohms?
  24. Does you 22re do this????
  25. Cost of labor?
  26. Alternator problem
  27. I need parts
  28. Rusted Rear Drums
  29. toyota will not turn sharp
  30. 95 4unner + shaking/struggling around 55
  31. Rear Leaf Spring Question on 1984 2WD pickup EX Cab
  32. A bunch of questions...
  33. FJ-40 1972 Stock Engine Gas Mileage?
  34. Questions about a 1994 4-runner
  35. can junkyard springs=lift?
  36. What a 2WD 5-speed transmission will fit 1988 22R?
  37. later year toyota 16" wheels for 1997 4runner
  38. Surging / Hunting Idle - '94 22re
  39. will a 22r fit 3vze trans/transfercase???
  40. Truck cap question...
  41. 22RE vs. 3vze
  42. Timing Belt Install
  43. Connector on wire Harness?
  44. Aternator and voltage regulator replaced but battery STILL does not charge?
  45. Engine Surging?
  46. Ok this might be a little long! Please take a look
  47. How to test...
  48. evap. canister(did a search)
  49. To Supercharge or not to Supercharge
  50. Code 71
  51. Just picked up a 91 4runner V6
  52. Newbie
  53. SAS on an 89 4runner
  54. Take a look at this pic! I need some help
  55. check engine light
  56. Question
  57. 90 22RE 4x4- Radiator leaking out of it's drain
  58. Question from a noob
  59. 89 runner
  60. Should my EGR be cold.....HELP
  61. Rad or themostat trouble
  62. thinking about a body lift
  63. Looking for a good toyota salvage yard!
  64. 3.4 swap and other options.
  65. Phenolic Carb Spacer????
  66. valve lash???
  67. Truck Gears Have Locked up???
  68. Exhaust inlet size quick question
  69. considering an SAS
  70. Shocks, Tire Sizes, Regearing, Locker, Confusing World!
  71. 87 turbo 4runner spedometer
  72. a couple propane questions
  73. Truck 4 sale
  74. Need Help!
  75. wheel bolt pattern on a 1989?
  76. Clutch question
  77. bfg a/t's for $65.00
  78. Power antenea trouble
  79. Hydrolocked but running
  80. 4.30'S OR 4.56's
  81. 87 Turbo 4runner gearing?
  82. Australia 4Runners
  83. Shock Absorber Kidney Failure
  84. vsv question.
  85. Egr???
  86. best choice???
  87. Clutch master/slave replacement
  88. 20" Wheels and 33's... what tires??
  89. 95 4runner shakes and sounds....
  90. looking for 95 4runner accessories
  91. got a ? about my pass door
  92. adda a leafs
  93. #2 cyl miss please help!!
  94. Peeling stickers of truck
  95. 1st Gen Automatic Transmission question?
  96. Going My Way? Need a Lift...
  97. Check engine light is on
  98. 22re missfire
  99. Question about 3.0 V6 Head Gaskets...
  100. Fsm
  101. A few newbie questions.
  102. Sway bar and brake hose crack
  103. Toyota Pickup Transmission care
  104. Pre-runner/Trophy truck build-up?
  105. Tranny Problems
  106. Problem while filling up at gas pumps?
  107. O2 sensor ???
  108. Looking for good Toyota salvage yard in SoCal
  109. more power
  110. 08 tacoma double cab shell on access cab
  111. 1st Gen 4Runner glove box t-case shift pattern sticker
  112. i have a question?
  113. Torque for chain dampers, and tensioner
  114. Is my truck from Canada???
  115. Warning: Extreme Newbie Question
  116. Removing motor
  117. A few`91 pickup questions
  118. overheating only on the freeway
  119. question on a wire w/plug.
  120. What are the exact Popular Mod Names for a 94 Runner
  121. Which Brembo rotors?
  122. 88 Pickup Stock 4wd front hub question
  123. greasing drive shaft
  124. alternator on the way out?
  125. 22re parts for sale!!!!
  126. Clay bar on uprotected paint?
  127. New to group - 93 4Runner starting problem
  128. shifter removal
  129. 95 4Runner
  130. truck only turns over half the time
  131. Cel
  132. No cat questions?
  133. Driver side electric mirror assembly on 95 4runner?
  134. Differentials & Transfer Case Tips
  135. Newbie Suspension Lift Questions
  136. gears or engine
  137. backfiring/not starting..Timing?
  138. newb on board
  139. larger tires and gas mileage
  140. suspension lift kit help
  141. newbs plan of attack for a clutch job
  142. OME Springs Stock Shocks
  143. Donahoe suspension
  144. Steering gear dust boot strap
  145. Changing url
  146. 93 4x4 brakes, can they be modified?
  147. i need help with a tranny conversion
  148. Changing Clutch!
  149. I need help installing DRL kit
  150. Bigger Rotors
  151. Tire HELP!?
  152. swap in tacoma engine in 86 p/u
  153. Flame on the newb
  154. Bad Distributor Housing?
  155. What's the difference between Tundra and Tacoma
  156. How can I increase my trucks power?
  157. Rebuilt Steering Gearbox leaking @free play nut!
  158. thumping noise and tire question
  159. FJ40 Bikini top and what is needed....
  160. front sway bars?
  161. 1993 4Runner front Drive axle removal HELP!
  162. rear bilstein shock install question
  163. front leafs on 85 pickup
  164. newbie to pictures-rear wing painted
  165. calling all genius'- help
  166. 2WD lockers
  167. Dumb Question - idler and pitman arm
  168. check engine, vibrations
  169. Anyone running 285's with OME 881 and 906 coils?
  170. New Toyota
  171. 4runner brake upgrade
  172. Spark Plug Question HELP!
  173. a little help with yota cases (thanks)
  174. rear seal
  175. Timing chain cover
  176. Rear Leaf springs
  177. Measuring Castor
  178. Engine swap options?
  179. deck light switch
  180. Rough Idle In 91 V6
  181. ???Which way???
  182. suspension lifts?
  183. 98 Tachoma running rough
  184. T-case and motor ???
  185. Rattling NOIse
  186. Good restoration parts catalog?
  187. Front end alignment
  188. Normal sound?
  189. 95 T-100 and spray washer...uggh!
  190. 87 4runner would like to SAS
  191. installing 4wd fenders. no power steering. newbie. help!
  192. Lift Kit
  193. Straight Pipes
  194. cams & gas milage
  195. Louder Truck
  196. a few clutch questions
  197. will those 2nd gen Aisin hubs work on 3rd gen?
  198. 87 22R Motor into 88 22RE
  199. spark plugs
  200. quick easy vacuum question
  201. Roll Bar light mounting
  202. Chirping noise coming from clutch
  203. Whats the difference between Land crusier axle and the 79-85 toyota pu axle?
  204. Very Very Very Rusty Bolts
  205. GM Top End Cleaner
  206. 89 4Runner Transmission noise in 3rd and 5th.
  207. Flowmaster?
  208. 95 4Runner,new owner rear window switch question...
  209. burping 3.4
  210. Spare tire
  211. Noob!!Hello and help me find some wheels
  212. Air box mods
  213. Removing rust from an engine block?
  214. 1 inch body lift questions
  215. Removing Trailer Hitch - any issues?
  216. 86 4Runner blue smoke from exhaust
  217. Re-gearing to 4.30 a good idea?
  218. Piston Size
  219. new owner lift questions
  220. want to make a frame repair.
  221. 33 x 10.50 or 12.50??
  222. Emissions system help, please. (pictures)
  223. Advantex clutch?
  224. how do i get these off?
  225. what is the best air filter to use
  226. does regearing...
  227. what engine upgrade to do first with
  228. Help with some of my problems
  229. I really wasn't sure where to put these questions but...
  230. 1990 runner in MN needs help
  231. back fire through the exhaust
  232. Rear wiper wont stop
  233. Inspection!
  234. Questions a plenty ref locker
  235. 22R-E Compatability
  236. GEN 1 into GEN 2
  237. 2WD for Snow???
  238. I Need Some Clarification on 3rd Member Interchangability
  239. New 4runner owner questions
  240. Newbie with timing chain question
  241. Regear needed for 31's or 32's?
  242. 87 motor in 89
  243. dist. cap ??
  244. Max Tire Size for 17" Rims
  245. Just Got A 90 Runner, What Should I Watch For?
  246. Difference between a prerunner and a regular tacoma
  247. Im a NOOB in here with a few questions
  248. Newbie Big 3 qestion?
  249. Help diagnosing oil leak 3VZE
  250. how to stop rust?
