Sponsored by: CARiD
87 motor in 89
Old Apr 2, 2008 | 05:26 PM
89runner22r's Avatar
87 motor in 89
Im putting a motor from a 1987 4runner into a 1989 4runner. Both the motors are 22re. Will i need to put more emission stuff onto the 87 motor? Or will everything be the same and will it drop right in?
Thanks
Old Apr 2, 2008 | 05:44 PM
bigarms23's Avatar
if they have the same emission codes than go ahead
Old Apr 2, 2008 | 05:52 PM
I know im going to swap the motors, but i want to know if they have different emission stuff on them.
Old Apr 2, 2008 | 06:05 PM
rdlsz24's Avatar
It should drop right in. Use your current ecu/harness if possible since you know it works.
Rob
Old Apr 2, 2008 | 06:10 PM
Ok thanks
Old Apr 3, 2008 | 05:11 PM
Also, when I pull the engine do I have to remove the EFI?
Old Apr 3, 2008 | 05:31 PM
rdlsz24's Avatar
You have two options. If you want to leave the wiring harness connected to the ecu then you will have to remove the intake plenum since the harness weaves through it. The second option is to pull the harness out through the firewall and leave the plenum in place. When I recently did my engine swap I left the harness in place and removed the plenum. It's only 6 bolts if I remember correctly.
Rob
Old Apr 3, 2008 | 05:34 PM
Ok so it would probably be easier to remove it, pull the engine, then install the engine and put it back on?
cars-guy
Aug 16, 2020 06:59 AM
okamikai
Apr 30, 2018 10:19 PM
Flossy
Aug 5, 2015 05:14 PM
msane99
Jul 17, 2015 10:13 AM
