87 motor in 89
87 motor in 89
Im putting a motor from a 1987 4runner into a 1989 4runner. Both the motors are 22re. Will i need to put more emission stuff onto the 87 motor? Or will everything be the same and will it drop right in?
Thanks
Thanks
You have two options. If you want to leave the wiring harness connected to the ecu then you will have to remove the intake plenum since the harness weaves through it. The second option is to pull the harness out through the firewall and leave the plenum in place. When I recently did my engine swap I left the harness in place and removed the plenum. It's only 6 bolts if I remember correctly.
Rob
Rob
Flossy
Aug 5, 2015 05:14 PM
