Sponsored by: CARiD
Engine Surging?
Old May 23, 2008 | 07:10 AM
my4runner's Avatar
Engine Surging?
A little help my friends, a friend of mine has a 92 toyota with 22re motor, he said the truck idles fine, but when he is on the highway, third-forth gear, the truck starts to surge,(buck) he changed the fuel filter, plugs, wires, still same problem,,,any ideas I can pass to him of what the problem could be?????
Thanks
Old May 23, 2008 | 10:24 AM
4Crawler's Avatar
See if there are any stored trouble codes in the ECU:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old May 23, 2008 | 10:55 AM
INFINITY's Avatar
check ECU for corrosion
Old May 23, 2008 | 12:24 PM
my4runner's Avatar
Motor surging.
Dont mean to sound dumb, what is the ECU, and what to check on that? Also, I will ask him to check for codes!!
Old May 23, 2008 | 12:30 PM
4Crawler's Avatar
a.k.a. Engine Computer or Electronic Control Unit, check codes per the link I posted earlier.
Old May 23, 2008 | 12:50 PM
jason191918's Avatar
Mine used to do this til I yanked the EGR.
Old May 23, 2008 | 01:46 PM
my4runner's Avatar
Thanks everyone, I will pass the info to my friend!!!!!!!!!!!
Old May 23, 2008 | 02:23 PM
SEAIRESCUE's Avatar
Probably running lean. O2 sensor, weak fuel pump, air/vacuum leak, timing issue, are a start. Put a vacuum gage on it when hot and at idle. Look for 18-20 steady inches of vacuum. That's a healthy motor. Filthy injectors are possible and a couple of cans of Berrymans injector cleaner will eliminate that concern. Any codes stored in the computer should be investigated immediately.
My $0.02
Old May 25, 2008 | 09:25 AM
Fallen213's Avatar
Hello. I have the exact same issue. Not to steal the forum at all, but maybe I can increase the importance of this thread. I have an 88 pickup and under heavy acceleration it will hesitate (or buck). If I am on the freeway I cannot go over about 65mph because it will hesitate. I have been told that it is probably a fuel problem. This is what I have done so far:
Changed the O2 Sensor
Checked all the spark plugs
Checked all the plug wires with an OHM gauge
Checked the EGR as the Chilton's manual instructs
Changed the fuel filter
I still have the problem. Any more advice would be great!
Old May 25, 2008 | 09:52 AM
4Crawler's Avatar
Could try adding some gauges to see what is going on. I run an air/fuel gauge to see what the O2 sensor is up to and a fuel pressure gauge to monitor the fuel pressure while driving:
http://www.4crawler.com/4x4/CheapTri...es/index.shtml
Old Jun 1, 2008 | 11:15 AM
Fallen213's Avatar
I fixed it
Just to follow up. I just changed my cap and rotor and my problems went away... Should have done that sooner...
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
