Sponsored by: CARiD
Which Brembo rotors?
Old May 4, 2008 | 01:33 PM
rockclimber's Avatar
So i need to do a front brake job 2004 tacoma. After searching here i have decided on brembo for rotors.
Head out to the local world wide web and do some searching to order. Found some on the tire rack and various other sites.
Brings me to my question. From searching here i was under the impression that the brembos were slotted or drilled or something.....what i find everywhere is just a basic looking rotor. Have i not found the fabled brembo rotor spoken so highly of in this forum? Or did i misunderstand? Un-slotted/drilled is fine with me....or did i just find their regular model?
Couldn't find "tacoma" listed on the brembo site?
Any suggestions?
thanks
RC
Old May 4, 2008 | 05:38 PM
DIHOWARD's Avatar
rotors
try STOP-TECH
http://www.stoptech.com/products/rotors.shtml
direct replacement rotors, bottom of the page.
mine are drilled and slotted, no problems after 20k.
check them out.
Old May 4, 2008 | 05:47 PM
bigarms23's Avatar
the brembos i have i got from northwestoffroad
Old May 4, 2008 | 05:53 PM
CJM's Avatar
CJM
Brembos are regular rotors, unless you order drilled and slotted.
Drilled or slotted does nothing, I dunno why people bother. If they worked so great wouldnt nascar use them.
Old May 5, 2008 | 04:21 AM
mkgarrison5's Avatar
brembo blanks are what you want. dont get the slotted and etc. now worth it.
Old May 5, 2008 | 06:27 AM
michalik_piotr's Avatar
sorry, but nascar is not the "end all to technology", they use push rod v8 engines and build cages that weigh a ton. If you want validation of performance of parts look at formula one where manufacturers like bmw, ferrari, and mclauren race not ford and chevy.
slotted and drilled rotors disepate heat faster therefore less chance of warping and also disapate water faster during wet weather conditions therefore stopping better and eliminating grab.
Old May 5, 2008 | 07:06 AM
CJM's Avatar
CJM
So explain to me why guys who are going 120mph+ wouldnt take advantage of them then?
We gain nothing buy using them on our trucks anyways, they arent fast and they dont need such things.
Old May 5, 2008 | 07:48 AM
infiltrator's Avatar
PEPBOYS SALE!!!
PROSTOP ROTORS
$9.99 for normal rotor
$24.99 for platinum brake rotor
SALE ON PADS TOO!
$9.99 for normal pads
$19.99 for platinum pads
$24.99 for CERAMIC pads
Old May 5, 2008 | 08:14 AM
why would they not take advantage of lots of things beginning with not using motor technology from the 1950's? pls, don't get me started about nascar, we might as well talk about pro wresting.
Old May 5, 2008 | 10:10 AM
esp on road courses and small tracks. they stay on the brakes. heck you even see them glo they get so hot.. they dont use slotted rotors and such. and you are right, WE do not need such brakes so save the $$ and get the blanks
Old May 5, 2008 | 11:46 AM
right we don't need them, otherwise toyota engineers would have put them on stock from the factory but there are not negative effects if someone wants them, only positive so if someone wants to upgrade....why not? its like putting on nicer wiper blades or better headlight bulbs, do we need them? no, is it nicer to have? besides the fact that the engineers did not deem it necessary obviously to instal better rotors then they did, they also have to think about keeping the cost down. as you notices slotted/drilled rotors cost more....and so do cars/trucks that come oem with them.
Old May 5, 2008 | 05:27 PM
CJM's Avatar
CJM
The reason I say we dont need them is our trucks will not generate the heat and speed to take advantage of them. So basically your wasting your money on them.
I could understand brighter lights to see, better tires to grip. But like I said, unless you ride the brakes all day long (and I mean have your foot on them while driving all over like some people do) you dont need them.
I used to race auto-x, I have done drag, I have done road courses, etc, etc. No one uses slotted/drilled rotors. If you wanna spend the extra cash on them, be my guest. Not like you will gain anything from them, what one would gain in terms of brake performance would be to upgrade the lines, calipers and use better brake pads.
Now..
Old May 6, 2008 | 05:05 AM
Now..
good post.... ill hug :-)
Old May 6, 2008 | 07:06 PM
Thanks for the info guys. The blank brembos sound like what i'm looking for. Sorry for stirring things up....not intended.
thanks again
RC
ladybugRC
458
Aug 21, 2020 10:41 AM
Kamaloha
Oct 16, 2015 05:13 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Toys4parts
Sep 26, 2015 01:56 PM
