Sponsored by: CARiD
87 4runner would like to SAS
Old Apr 19, 2008 | 01:13 AM
874runner's Avatar
Hey guys im new here. I own a 87 4runner with 3" body and 33's my question is i want to do a SAS on it and take off the body lift. but add a 4" suspension lift is it cheaper for the lift kit if i have a SAS? also what year toyota should i get the axle out of? and is there any tutorials on how to do it? any info helps! thanks.
Old Apr 19, 2008 | 05:52 AM
waskillywabbit's Avatar
Welcome to Yotatech.
You need to do a LOT of reading and research because your questions clearly demonstrate you have no clue what you are asking.
A solid axle swap typically involves lifting the vehicle in order to do the swap. Most kits are 3-5".
Typically the 79-85 solid front axle is used.
Tutorials? Search the Toyota online forums and It has been done just a few times before.
Go read this - all of it!
http://www.pirate4x4.com/forum/showthread.php?t=459180
Old Apr 20, 2008 | 12:21 AM
Lysmachia's Avatar
Yes welcome. We moved your post due to the nature of your post. When you do a little more research and search YotaTech or Google, and have more specific questions, then you can post under your model/year...
Old Apr 21, 2008 | 12:53 AM
874runner's Avatar
ok thanks. sorry im new
Old Apr 21, 2008 | 02:56 PM
bigarms23's Avatar
all you need is a 4inch sas kit from marlin crawler and an 83 to 85 toyota front axle gears and rebuild the front axle
Old Apr 21, 2008 | 03:00 PM
bigt's Avatar
yeah.. i was looking into a s.a.s too but its still a little beyond me yet... first im going locked rear then well see how far i can go with that and a winch... you need a solid axle from a 83-85 toyota truck. get a kit from a company like wab fab or trailgear or marlin and you can choose the 4 inch kits .. its around 1200... if you have a first gen runner you have leafs in the rear and can get some new leafs and coils to get the lift you need. if its a newer runner you need a kit like the s.a.s
gotta run
search is your friend and so am I
welcome to yt
Old Apr 21, 2008 | 03:01 PM
Not quite...and front drive shaft work and then the front SAS is done.
What about the rear? Lockers? Gears? Armor? The list goes on and on and on.
Old Apr 21, 2008 | 03:14 PM
dropzone's Avatar
Fossilized
welcome to an addicting hobby...I feel an SAS conversion is a good route to go, but there are some folks,TC, for instance that can wheel some very difficult places with IFS because he knows how to drive.
This all Toyota Search Engine might give you another source. It hits over 50 Toyota Technical sources...
like Wabbit said, keep reading and searching. You will find that you will be abe to answer many questions you have. Of course some new ones are gonna come up
Last edited by dropzone; Apr 21, 2008 at 03:15 PM. Reason: fix linky thingamachigger
Old Apr 24, 2008 | 03:03 PM
bigarms23's Avatar
I could add add a set of longtravel je reel driveshafts but you can do an sas without a front friveshaft but you won't be able to use the 4wd
Old Apr 24, 2008 | 03:17 PM
sambeano420's Avatar
Hi, Iam new here too, but I will throw in an answer. 84 and 85 front axles are best, they were beefed more from the factory, but would add the weld on armor and ball braces and longfields. Also recommend going to 63" 3/4 ton Chevy springs in the rear, with the bottom 2 leaves taken out. did it to a buddys 85 and it flexes incredibly.
Old Apr 26, 2008 | 09:09 PM
874runner's Avatar
Well thanks for all the input guys. Im not sure if im built up to the SAS yet i want to do it but need to read further it looks like. Besides ive only had the truck not even a year yet lol. So far it wheels very nicely the way it is but maybe i should do gears and lock the rear first?
Old Apr 26, 2008 | 09:15 PM
Spence1016's Avatar
that would be the best place to start, there are very few places you can get with a sas that you cant with ifs
Old Apr 26, 2008 | 09:22 PM
874runner's Avatar
well im sort of new to wheeling as well but so far every terrain and/or trail ive taken it down its never had a problem couple took a few tries but it made it every time.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
crashburnoveride
Aug 28, 2015 09:20 PM
karbin
Jul 5, 2015 11:37 PM
